AIR CAP 3602E-E-K9 NEW AUTONOMOUS IOS CAN,T LOAD PROPERLY DEVICE IS NOW IN AP MODE
RASHID ASGHAR
ap: boot
Loading "flash:/ap3g2-k9w7-mx.152-4.JA1/ap3g2-k9w7-xx.152-4.JA1"...flash:/ap3g2-
k9w7-mx.152-4.JA1/ap3g2-k9w7-xx.152-4.JA1: no such file or directory
Error loading "flash:/ap3g2-k9w7-mx.152-4.JA1/ap3g2-k9w7-xx.152-4.JA1"
Interrupt within 5 seconds to abort boot process.
Loading "flash:/ap3g2-k9w7-mx.152-4.JA1/ap3g2-k9w7-mx.152-4.JA1"...#############
File "flash:/ap3g2-k9w7-mx.152-4.JA1/ap3g2-k9w7-mx.152-4.JA1" uncompressed and i
nstalled, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Xmodem file system is available.
ap: boot
Unable to locate IOS image with name **xx**.
Boot CMD: 'flash:/ap3g2-k9w7-xx.152-4.JA1/ap3g2-k9w7-mx.152-4.JA1'
Loading "flash:/ap3g2-k9w7-xx.152-4.JA1/ap3g2-k9w7-mx.152-4.JA1"...flash:/ap3g2-
k9w7-xx.152-4.JA1/ap3g2-k9w7-mx.152-4.JA1: no such file or directory
Error loading "flash:/ap3g2-k9w7-xx.152-4.JA1/ap3g2-k9w7-mx.152-4.JA1"
Boot process failed...
ap:
ap:
ap:
DEVICE IS NOW IN AP MODE  HOW CAN I EASILY LOAD ANOTHER IOS............................TELL ME SOME AP MODE COMMANDS
Please goes a long way matey :-).
The experts can probably correct me here but it looks like your IOS is in  "flash:/ap3g2-k9w7-mx.152-4.JA1/ap3g2-k9w7-mx.152-4.JA1" and your AP is trying to boot from: "flash:/ap3g2-k9w7-mx.152-4.JA1/ap3g2-k9w7-xx.152-4.JA1"
So firstly, try using the following command:
set boot flash:/ap3g2-k9w7-mx.152-4.JA1/ap3g2-k9w7-mx.152-4.JA1
then issue the 'boot' command and see if that works.
If not, grab a copy of your IOS and setup a TFTP server connected to your Access Point. You may need to turn off your personal firewall when you do this.
Follow the instructions at this link which explain it on an 1142 which should be the same method:
https://supportforums.cisco.com/docs/DOC-14636
Let us know how you go!
Thank you Richard, that worked perfectly for me.
