429
Highlighted
Beginner
AIR CAP-702-H-K9 Does not connect to the controller
1 access point is not connected to the controller ,. Boot log
U-Boot 1.1.4.v5.3 (Jan 31 2013 - 12:54:33)
DRAM:  128 MB
CPU: 560 MHz
Top of RAM usable for U-Boot at: 88000000
Reserving 283k for U-Boot at: 87fb8000
Reserving 144k for malloc() at: 87f94000
Reserving 44 Bytes for Board Info at: 87f93fd4
Reserving 36 Bytes for Global Data at: 87f93fb0
Reserving 128k for boot params() at: 87f73fb0
Stack Pointer at: 87f73f98
Now running in RAM - U-Boot at: 87fb8000
Flash Manuf Id 0xc2, DeviceId0 0x20, DeviceId1 0x14
flash size 1MB, sector count = 64
Flash:  1 MB
Fetching MAC Address from 0x87fe3908
eth0: 34:6f:90:c3:fb:b4
ATHRSF1_PHY: Port 4, Negotiation timeout
Ethernet link down
eth0
Ether initialization ok!
Atheros on-chip NAND FLash Controller Driver, Version 0.1 (c) 2010 Atheros Communications, Ltd.
Ath Nand ID[87ff117c]: 2c:f1:80:95:02
ONFI MICRON      MT29F1G08ABADAWP
Micron NAND 128MiB 3,3V 8-bit [128MB]
====== NAND Parameters ======
sc = 0x87ff1158 bbt = 0x87f98360 bbt_size = 0x100 nf_ctrl = 0x344
page = 0x800 block = 0x20000 oob = 0x40
size = 128MB
Setting 0xb8116290 to 0x28502d0f
Test Size=0x8000000, Start!!
RAM test complete!
PTD Init
MAC address check ok!
boot method:3
Hit "ESC" to stop autoboot:  0
Uncompressed size: 320755 = 0x4E4F3
Loading .text @ 0x84000000 (205856 bytes)
Loading .rodata @ 0x84032420 (38368 bytes)
Loading .data @ 0x8403ba00 (3232 bytes)
Loading .data.rel.local @ 0x8403c6a0 (992 bytes)
Loading .data.rel @ 0x8403ca80 (124 bytes)
Loading .data.rel.ro.local @ 0x8403cafc (92 bytes)
Loading .data.rel.ro @ 0x8403cb58 (960 bytes)
Clearing .bss @ 0x8403cf20 (161112 bytes)
Clearing .scommon @ 0x84064478 (60 bytes)
## Starting application at 0x84000000 ...
IOS Secondary Bootloader - Starting system.
Ath Nand ID: 95:80:f1:2c:00
Using driver version 1 for media type 2
Valid buffers 120
total120  120
success found all blocks
start end 65 73
found in range
high low end 2342 2088 73
Invalid version Number for sector = 1055724 read =  35082 expect =2314Xmodem file system is available.
mifs[0]: 8 files, 2 directories
mifs[0]: Total bytes     :  131334144
mifs[0]: Bytes used      :    7585792
mifs[0]: Bytes available :  123748352
mifs[0]: mifs fsck took 0 seconds.
Base Ethernet MAC address: 34:6f:90:c3:fb:b4
Setup MAC....
Waiting for PHY auto negotiation to complete...Port 4 Negogiation timeout.
Ethernet link is down.
Setting Drop CRC Errors, Pause Frames and Length Error frames
: cfg1 0x7 cfg2 0x7114
Loading "flash:/ap1g1-rcvk9w8-mx.152-4.JA/ap1g1-rcvk9w8-mx.152-4.JA"...########################################################################################################################################################################################################bad mzip file, unknown zip method
Error loading "flash:/ap1g1-rcvk9w8-mx.152-4.JA/ap1g1-rcvk9w8-mx.152-4.JA"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The system is unable to boot automatically.  The BOOT
environment variable needs to be set to a bootable
image.
ap1g1 Boot Loader (ap1g1-BOOT-M) Version 15.2(4)JA, RELEASE SOFTWARE (fc1)
Compiled Tue 18-Jun-13 14:15 by prod_rel_team
Is it possible to restore it, apparently, she cannot download something.
Everyone's tags (1)
4 ACCEPTED SOLUTIONS
VIP Mentor
Re: AIR CAP-702-H-K9 Does not connect to the controller
paste the output of these commands:
sh syinfo from WLC
sh version from AP
and paste the complete boot-up process logs from AP console.
Dont forget to arte helpful posts
VIP Mentor
you are using AP:
AIR CAP-702I-H-K9  --> its for China not for Russia and Ukriane
And you set the WLC country code RU & UA.
So its the issue with regulatoiry domain.
Solution: Either change the AP with AIR CAP-702I-R-K9 or add the CN country code(cisco dont recommand to do that) in WLC.
VIP Mentor
as per logs..."bad mzip file" means, the file may be corrupt.
Reboot the AP and paste the complete logs from AP Console.
Dont forget to rate helpful posts
VIP Mentor
try to upload new software on AP:
here is the process:
https://community.cisco.com/t5/wireless-mobility-documents/access-point-rommon-recovery-ap-prompt-recovery-example/ta-p/3119495
9 REPLIES 9
VIP Mentor
sh syinfo from WLC
sh version from AP
Beginner
Full log bootup process log in my first message
ap: version
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.5.131.0
RTOS Version..................................... 8.5.131.0
Bootloader Version............................... 8.1.120.0
Emergency Image Version.......................... 8.1.120.0
OUI File Last Update Time........................ Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... IST_WLC1
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 10.10.0.2
IPv6 Address..................................... ::
System Up Time................................... 0 days 21 hrs 0 mins 28 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries : RU,UA
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 102
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 00:0C:29:9A:62:85
Maximum number of APs supported.................. 200
System Nas-Id.................................... IST_WLC1
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Small
VIP Mentor
you are using AP:
Beginner
But I already have the same points. I think that's not the problem. During the download in the log says that something could not load, and constantly lit red.
VIP Mentor
Beginner
ap:
DRAM:  128 MB
CPU: 560 MHz
Flash:  1 MB
Ethernet link down
eth0
size = 128MB
RAM test complete!
PTD Init
boot method:3
Valid buffers 120
total120  120
start end 65 73
found in range
Setup MAC....
image.
ap:
VIP Mentor
Beginner
I have a point 702, and tell me where to get the firmware for it?
VIP Advocate
Cisco download site are the images for the AP.
You also should have 10 years of warranty on the hardware, you are probably quicker by replacing it.
Content for Community-Ad
August's Community Spotlight Awards
