Ask Me Anything – How to Enable Network Connectivity to Remote Workers
333
Highlighted
Beginner
AIR-LAP Does not Join With WLC2100
Dear All,
Our offcie use WLC2100 Series controller with AIR-LAP1031 and successfully join and running. Now i am trying to replace one ap with AIR-LAP1041N and join with WLC, but i can't and below  the error message generate:
*Mar 25 02:37:28.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.9 peer_port: 5246
*Mar 25 02:37:28.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Mar 25 02:37:29.397: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.9 peer_port: 5246
*Mar 25 02:37:29.398: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.9
*Mar 25 02:37:29.399: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Mar 25 02:37:29.410: %CAPWAP-3-ERRORLOG: This AP is not supported in controller version 6.0.199.4
*Mar 25 02:37:29.493: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Mar 25 02:37:29.493: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.9:5246
*Mar 25 02:37:29.495: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Mar 25 02:37:29.549: %CAPWAP-3-ERRORLOG: Dropping dtls packet since session is not established.
*Mar 25 02:37:39.548: %CAPWAP-3-ERRORLOG: Go join a capwap controller
Can you please help me how can i solve the problem ?
Please see the attached.
Reagrds and waiting for your reply?
Palash.
2 ACCEPTED SOLUTIONS
Highlighted
Hall of Fame Community Legend
Re: AIR-LAP Does not Join With WLC2100
Upgrade the WLC 2106 firmware to 7.0.240.0.  This firmware will support the newer 1040, however, this version will NOT be able to support the older 1030.
You either replace your very old 1030 or run the 1040 on autonomous IOS.
Highlighted
Hall of Fame Master
Leo is correct:). For reference, here is the compatibility matrix.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html
-Scott
2 REPLIES 2
Highlighted
Highlighted
Hall of Fame Master
-Scott
Content for Community-Ad
Cisco COVID-19 Survey
