03-23-2012 10:41 AM - edited 07-03-2021 09:51 PM
Hello, I have two Aironet 1310s out doors - one on a boat and the other on a building. I have one ANT24120 antennas attached to each AP. I am trying to determine why I am having dropped connections. Any help would be appreciated.
03-23-2012 12:45 PM
You have a 1310 on a boat ? Really.... Interesting...
So was this working before and just stopped working?
03-23-2012 01:10 PM
Yes, it was working, but is now sporadic.
03-23-2012 01:12 PM
I am new to setting up wireless networks over such a distance. I have discovered a "distance" setting on the 1310. The APs have been wiped and re-configed. To your knowledge, could the distance setting play a part in my problem?
03-23-2012 01:14 PM
What distance are you trying to shoot and are out in the ocean / lake and trying to get a connection or at the dock?
03-23-2012 01:13 PM
Ok good to know.
1) Has anything changed to the network, the bridges, or the surrounds that could cause a problem?
2) Have you reset the bridges as part of any testing (both)
3) Do you have access to both bridges ?
03-23-2012 01:19 PM
1) I do not know if anything has changed (at least not with each AP or antenna). I am guessing there is more RF noise. I ran a product called wi-spy and channelizer. There was a lot of competition, so I hard-coded a channel that was consistently lower in noise.
2. I have reset both bridges.
3. I will not have physical access to both bridges till Monday.
4. I am trying to get up to about 5 miles. I am having intermmitent issues while docked as well.
03-23-2012 01:46 PM
So you have / had this working while in the ocean ? A PTP is a very fine link and not like sat or cellular. A ptp is a direct connetion and even a slight move from one bridge could cause you to have a signal break. So you got this working in the ocean / lake ?
I notice you are using an omni 12 dBi on both .. You were getting 5 miles from that, are you sure this worked before?
03-23-2012 01:48 PM
Yes. The antennas are omnidirectional - ANT24120
03-23-2012 01:50 PM
Are you line of sight between your antennas and the base anatnna ?
03-23-2012 01:51 PM
Yes.
03-23-2012 01:56 PM
If you reset both bridges you will need to reconfigure both. Here is an exmaple config. Give this a read..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
Once you get this up we can then test signal. Did you save the wispy captures, if so i would be glad to taje a peek at them.
03-23-2012 05:08 PM
ASDF I understand it's a PtP link but check out this guide written by Javier. It's solve many issues with my PtP links and PtMP roaming events.
https://supportforums.cisco.com/docs/DOC-14944
03-23-2012 05:15 PM
Have you checked to see if the antenna connectors and or cabling is corroded? Environments like yours really need I have coax seal applied correctly.
03-23-2012 05:39 PM
Agreed. Salt is very corrosive. Wrap it in weather proof tape on all connectors and then electrical tape. Probably will have to replace coax cables on the boat since the damage has been done
