280
Beginner
Aironet 1562E Poor download speed 802.11ac
Hi. I`ve setup 1562E on wlc 5500, i connect to AP 866.7-780Mbps. But the transfer speed is awful.
Download speed vary from 2-7mb/s, when working in 802.11n i get better download speeds 12-14 mb/s
Transmit is somewhere around 20 mb/s
Receiving/download
============== cut ===================
[ 5] local 10.41.99.11 port 5201 connected to xxxx port 54755
[ ID] Interval Transfer Bandwidth
[ 5] 0.00-1.00 sec 2.24 MBytes 18.8 Mbits/sec
[ 5] 1.00-2.00 sec 2.62 MBytes 22.0 Mbits/sec
[ 5] 2.00-3.00 sec 1.27 MBytes 10.6 Mbits/sec
[ 5] 3.00-4.00 sec 1.01 MBytes 8.46 Mbits/sec
[ 5] 4.00-5.00 sec 880 KBytes 7.20 Mbits/sec
[ 5] 5.00-6.00 sec 1.04 MBytes 8.76 Mbits/sec
[ 5] 6.00-7.00 sec 898 KBytes 7.36 Mbits/sec
[ 5] 7.00-8.00 sec 593 KBytes 4.86 Mbits/sec
[ 5] 8.00-9.00 sec 4.70 MBytes 39.4 Mbits/sec
[ 5] 9.00-10.00 sec 3.58 MBytes 30.0 Mbits/sec
[ 5] 10.00-10.05 sec 0.00 Bytes 0.00 bits/sec
[ 5] 0.00-10.05 sec 0.00 Bytes 0.00 bits/sec sender
[ 5] 0.00-10.05 sec 18.8 MBytes 15.7 Mbits/sec receiver
Sending, transmit
[ 4] 0.00-1.00 sec 29.1 MBytes 244 Mbits/sec
[ 4] 1.00-2.00 sec 26.4 MBytes 221 Mbits/sec
[ 4] 2.00-3.00 sec 24.4 MBytes 205 Mbits/sec
[ 4] 3.00-4.00 sec 24.5 MBytes 206 Mbits/sec
[ 4] 4.00-5.00 sec 23.2 MBytes 195 Mbits/sec
[ 4] 5.00-6.00 sec 26.6 MBytes 223 Mbits/sec
[ 4] 6.00-7.00 sec 24.1 MBytes 203 Mbits/sec
[ 4] 7.00-8.00 sec 24.8 MBytes 208 Mbits/sec
[ 4] 8.00-9.00 sec 24.2 MBytes 203 Mbits/sec
[ 4] 9.00-10.00 sec 24.8 MBytes 208 Mbits/sec
[ 4] 0.00-10.00 sec 252 MBytes 211 Mbits/sec sender
[ 4] 0.00-10.00 sec 252 MBytes 211 Mbits/sec receiver
DCA
40, 44, 48, 52, 56, 60, 64, 149, 153, 157, 161
80/160/best no difference
Channel Width
20 MHz  40 MHz 80 MHz 160 MHz Best
4 REPLIES 4
VIP Mentor
Re: Aironet 1562E Poor download speed 802.11ac
how is the wlan configired ?
Paste the output of the command:
sh wlan <id>
Highlighted
Beginner
WLAN Identifier.................................. 3
Profile Name..................................... TestWifi
Network Name (SSID).............................. TestWifi
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Enabled
Network Admission Control
Client Profiling Status
Radius Profiling ............................ Disabled
DHCP ....................................... Disabled
HTTP ....................................... Disabled
Local Profiling ............................. Enabled
DHCP ....................................... Enabled (Auto)
HTTP ....................................... Enabled (Auto)
Radius-NAC State............................... Disabled
SNMP-NAC State................................. Disabled
Quarantine VLAN................................ 0
Maximum Clients Allowed.......................... Unlimited
Security Group Tag............................... Unknown(0)
Maximum number of Clients per AP Radio........... 200
ATF Policy....................................... 0
Number of Active Clients......................... 10
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
User Idle Timeout................................ Disabled
Sleep Client..................................... disable
Sleep Client Timeout............................. 720 minutes
Web Auth Captive Bypass Mode..................... None
User Idle Threshold.............................. 0 Bytes
NAS-identifier................................... none
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ corporate
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
WLAN Layer2 ACL.................................. unconfigured
mDNS Status...................................... Enabled
mDNS Profile Name................................ default-mdns-profile
DHCP Server...................................... Default
Central NAT Peer-Peer Blocking................... Unknown
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Tunnel Profile................................... Unconfigured
PMIPv6 Mobility Type............................. none
PMIPv6 MAG Profile........................... Unconfigured
PMIPv6 Default Realm......................... Unconfigured
PMIPv6 NAI Type.............................. Hexadecimal
PMIPv6 MAG location.......................... WLC
Quality of Service............................... Silver
Per-SSID Rate Limits............................. Upstream Downstream
Average Data Rate................................ 0 0
Average Realtime Data Rate....................... 0 0
Burst Data Rate.................................. 0 0
Burst Realtime Data Rate......................... 0 0
Per-Client Rate Limits........................... Upstream Downstream
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... 802.1P (Tag=0)
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
Authentication................................ xx.xx.xx.xx 1812
Authentication................................ xx.xx.xx.xx 1812 *
Accounting.................................... Disabled
Dynamic Interface............................. Disabled
Dynamic Interface Priority.................... wlan
Local EAP Authentication......................... Disabled
Radius NAI-Realm................................. Disabled
Mu-Mimo.......................................... Enabled
Security
802.11 Authentication:........................ Open System
FT Support.................................... Disabled
Static WEP Keys............................... Disabled
802.1X........................................ Disabled
Wi-Fi Protected Access (WPA/WPA2)............. Enabled
WPA (SSN IE)............................... Disabled
WPA2 (RSN IE).............................. Enabled
TKIP Cipher............................. Disabled
AES Cipher.............................. Enabled
CCMP256 Cipher.......................... Disabled
GCMP128 Cipher.......................... Disabled
GCMP256 Cipher.......................... Disabled
OSEN IE.................................... Disabled
Auth Key Management
802.1x.................................. Enabled
PSK..................................... Disabled
CCKM.................................... Disabled
FT-1X(802.11r).......................... Disabled
FT-PSK(802.11r)......................... Disabled
PMF-1X(802.11w)......................... Disabled
PMF-PSK(802.11w)........................ Disabled
OSEN-1X................................. Disabled
SUITEB-1X............................... Disabled
SUITEB192-1X............................ Disabled
FT Reassociation Timeout................... 20
FT Over-The-DS mode........................ Enabled
GTK Randomization.......................... Disabled
SKC Cache Support.......................... Disabled
CCKM TSF Tolerance......................... 1000
Wi-Fi Direct policy configured................ Disabled
EAP-Passthrough............................... Disabled
CKIP ......................................... Disabled
Web Based Authentication...................... Disabled
Web Authentication Timeout.................... 300
Web-Passthrough............................... Disabled
Mac-auth-server............................... 0.0.0.0
Web-portal-server............................. 0.0.0.0
qrscan-des-key................................
Conditional Web Redirect...................... Disabled
Splash-Page Web Redirect...................... Disabled
Auto Anchor................................... Disabled
FlexConnect Local Switching................... Disabled
FlexConnect Central Association............... Disabled
flexconnect Central Dhcp Flag................. Disabled
flexconnect nat-pat Flag...................... Disabled
flexconnect Dns Override Flag................. Disabled
flexconnect PPPoE pass-through................ Disabled
flexconnect local-switching IP-source-guar.... Disabled
--More-- or (q)uit
FlexConnect Vlan based Central Switching ..... Disabled
FlexConnect Local Authentication.............. Disabled
FlexConnect Learn IP Address.................. Enabled
Client MFP.................................... Optional
PMF........................................... Disabled
PMF Association Comeback Time................. 1
PMF SA Query RetryTimeout..................... 200
Tkip MIC Countermeasure Hold-down Timer....... 60
Eap-params.................................... Disabled
AVC Visibilty.................................... Enabled
AVC Profile Name................................. AVC-Profile-Corporate
OpenDns Profile Name............................. None
OpenDns Wlan Mode................................ ignore
Flow Monitor Name................................ NetFlow_Mon1
Split Tunnel Configuration
Split Tunnel................................. Disabled
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Assisted Roaming Prediction Optimization......... Disabled
802.11k Neighbor List............................ Disabled
802.11k Neighbor List Dual Band.................. Disabled
802.11v Directed Multicast Service............... Disabled
802.11v BSS Max Idle Service..................... Enabled
802.11v BSS Transition Service................... Disabled
802.11v BSS Transition Disassoc Imminent......... Disabled
802.11v BSS Transition Disassoc Timer............ 200
802.11v BSS Transition OpRoam Disassoc Timer..... 40
DMS DB is empty
Band Select...................................... Enabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Universal Ap Admin............................... Disabled
Broadcast Tagging................................ Disabled
PRP.............................................. Disabled
Mobility Anchor List
WLAN ID IP Address Status Priority
802.11u........................................ Disabled
MSAP Services.................................. Disabled
--More-- or (q)uit
Local Policy
Priority Policy Name
Lync State ...................................... Disabled
Audio QoS Policy................................. Silver
Video QoS Policy................................. Silver
App-Share QoS Policy............................. Silver
File Transfer QoS Policy......................... Silver
QoS Fastlane Status.............................. Disable
Selective Reanchoring Status..................... Disable
Lobby Admin Access............................... Disabled
Fabric Status
--More-- or (q)uit
Fabric status.................................... Disable
Vnid Name........................................
Vnid............................................. 0
Applied SGT Tag.................................. 0
Peer Ip Address.................................. 0.0.0.0
Flex Acl Name....................................
Flex Avc Policy Name.............................
U3-Interface................................... Disable
U3-Reporting Interval.......................... 30
Hall of Fame Community Legend
What is the wireless NIC that is doing this so-called "speed test" and what wireless driver is the wireless NIC loaded with?
Provide the complete model number of the wireless NIC.
What firmware is the WLC running on?
Beginner
Intel(R) Wireless-AC 9560 160MHz (Intel Dual Band Wireless AC 9560 (802.11ac) 2x2 Bluetooth 6.0) Dell Laptop 5591
Intel Driver 24.04.2019 21.10.1.2
WLC Software Version 8.5.140.0
AIR-CT5508-K9
Content for Community-Ad
August's Community Spotlight Awards
