12-24-2014 03:15 AM - edited 07-05-2021 02:10 AM
I have a WLC under version 7.6.130 and some APs 2702 and 3702. When trying to set the channels manually ("custom" ) from the WLC, I cannot find the choices 120, 124, 128. Can somebody tell why we cannot set up these values ? Our APs have been ordered for the ETSI ("E") regulatory domain.
Thanks. Marc.
Solved! Go to Solution.
12-24-2014 03:34 AM
Take a look under the wireless tab and then 802.11a/n/ac. Then go to RRM > DCA and you have to enable the channels to be available. These are the unii-2 extended. Be careful using these is devices don't support them as they will cause more issue for you.
EDIT:
Sorry but they are not unii-2 extended. I don't even think those are valid channels to use.
-Scott
12-24-2014 03:34 AM
EDIT:
-Scott
12-24-2014 04:33 AM
Hi Scott,
Thank you for your answer.
About your last sentence : "if devices don't support them as they will cause more issue for you".
Do you mean my user devices (PCs, Tablets) or the Access Points themselves ?
What kind of problems do you mean ?
Thanks. Marc.
12-24-2014 08:59 AM
You need to look at the manufacture website to see if they support unii-2 extended.... many devices do not support those channels and if an access point uses those channels, well the device will not be able to communicate and it would seem like there is no coverage. That is why you need to be careful when enabling unii-2 extended.
-Scott
