03-26-2020 04:31 PM - edited 07-05-2021 11:53 AM
My company did an upgrade to their WiFi access points and I ended up getting one of the Aironet 2700i APs. I was able to install the autonomous firmware and got it working. I have a Linux system performing firewall and DHCP services. When a device connects to the Aironet, the DHCP server reports that a different MAC address has requested an IP than what is on the device. I looked on the Aironet client list and the correct MAC address is there. Even more curious is that I get a different MAC address for the client if I connect to 2.4GHz or 5GHz. Since some of the devices are set with a static IP based on their MAC address, the DHCP server is giving out an IP from the pool instead of the static one.
Why is the Aironet forwarding a different MAC address and how can I get it to forward the devices correct one?
Solved! Go to Solution.
03-26-2020 04:51 PM
03-26-2020 04:51 PM
03-26-2020 05:23 PM
Do you know off hand where that setting is?
03-26-2020 05:40 PM
Oh, sorry. No, the device isn't randomizing the MAC (non-Cisco APs don't have this issue).
03-26-2020 05:42 PM
03-26-2020 06:21 PM
04-23-2020 09:59 AM
Sorry if I wasn't clear. The Android device was randomizing the MAC address by default. The option was buried and on by default. Regular home routers don't allow for that, so I hadn't run into it before.
