04-20-2009 10:15 PM - edited 07-03-2021 05:27 PM
Anyone had success using Windows 2008 NPS with a WLC to authenticate wireless users via RADIUS.
Was finding that I could get machine accounts to authenticate successfully against NPS and get on the wireless networks. If client user accounts attempted to authenticate it would fail.
I moved back to Windows 2003 IAS and things work fine. I was seeing Authenticate-Reject messages on the WLC debug when going against the NPS box but the logging on NPS is abhorrent and wasn't giving me any suggestions on why things were being rejected.
Anyone experienced the same?
01-10-2012 02:20 AM
Hi Nathan,
Did you resolve this issue. I am experiencing the same issue right now.
Thanks for your reply.
Greetz
Geert
01-10-2012 04:32 AM
Are you trying to authentic just users and not machine? On NPS you can only authenticate one or the other and not both. On ACS you can do both.
Scott Fella
Sent from my iPhone
01-10-2012 04:44 AM
We are trying to authenticate just users.
Met vriendelijke groeten,
Cliënt ICT Groep
Geert Reijnders
Verzonden: dinsdag 10 januari 2012 13:33
Aan: Geert Reijnders
Onderwerp: - Re: Any experience with Windows 2008 NPS and WLC
Home<>>
created by Scott Fella<> in Other Wireless - Mobility Subjects - View the full discussion<>>>
01-10-2012 05:07 AM
Okay... So can you post a screen shot of the NPS connection and network policy and also the failed log in the event viewer. Are you able to do machine authentication at least?
Scott Fella
Sent from my iPhone
