06-27-2012 07:09 AM - edited 07-03-2021 10:21 PM
Hi can anybody tell me that cisco 1AIR-LAP1142N-E-K9 will support clean air techonology or not ?
I have WLC AIR-CT5508-50-K9 .. IT seems that WLC is supporting the clean air .
Can any body give we with this WLC what are the new features avaliable . Can the clients able to authenticate with active directory bye
integrating WLC with LDAP without any ACS or Radius server
06-27-2012 07:35 AM
1142 does not support Clear Air.
Authentication via LDAP is possible, but not with MSCHAPv2 (e.g. PEAP-MSCHAPv2).
I would recommend using a Radius Server like IAS/NPS, ACS or freeradius.
regards
Stefan
06-27-2012 05:19 PM
No. CleanAir is the exclusive domain of the 3500 and the 3600 WAPs only.
Depends on the firmware of the controller. CleanAir is supported in the 7.0.98.0 firmware (if memory serves correct).
Each individual Release Notes will give you description to different features and/or bug fixes. They can be found here.
06-28-2012 07:57 AM
Webauth using LDAP on WLC:
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a0080a03e09.shtml
