2173
Beginner
AP 1231 vlan problem multiple ssid
Hi all,
I have troubles configuring the AP. This is what i want:
1 wireless network SSID WORTEL (vlan 1, my internal network)
1 wireless network SSID GUEST_NETWORK (vlan 10, for guests and user2)
With this config only the GUEST_NETWORK have internet access. WORTEL don't even get an ip address from the dhcp server.
See below for the config of the devices.
Thanks in advance for your replies!
ROTER CONFIG (CISCO871-SEC-K9):
Building configuration...
Current configuration : 2824 bytes
! Last configuration change at 11:33:23 UTC Wed Jun 15 2011 by x
! NVRAM config last updated at 11:37:26 UTC Wed Jun 15 2011 by x
version 12.4
no service pad
service password-encryption
hostname x
boot-start-marker
boot system flash:c870-advipservicesk9-mz.124-24.T2.bin
boot-end-marker
logging message-counter syslog
aaa new-model
aaa authentication login default local
aaa session-id common
dot11 syslog
ip source-route
ip dhcp excluded-address 172.16.1.1 172.16.1.49
ip dhcp excluded-address 172.16.1.100 172.16.1.255
ip dhcp pool user1
   network 172.16.1.0 255.255.255.0
   default-router 172.16.1.1
   dns-server 213.46.228.196 62.179.104.196
ip dhcp pool user2
   network 172.16.10.0 255.255.255.0
   default-router 172.16.10.1
ip dhcp pool user3
   network 172.16.20.0 255.255.255.0
   default-router 172.16.20.1
ip dhcp pool user4
   network 172.16.30.0 255.255.255.0
   default-router 172.16.30.1
ip cef
no ip domain lookup
ip domain name x
no ipv6 cef
username x privilege 15 password 7 x
archive
log config
  hidekeys
ip ssh version 2
interface FastEthernet0
description LINK TO user1
switchport mode trunk
interface FastEthernet1
description LINK TO user2
switchport access vlan 10
interface FastEthernet2
description LINK TO user3
switchport access vlan 20
interface FastEthernet3
description LINK TO user4
switchport access vlan 30
interface FastEthernet4
description WAN INTERFACE
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
ip address 172.16.1.1 255.255.255.0
ip nat inside
interface Vlan10
description user2
ip address 172.16.10.1 255.255.255.0
ip nat inside
interface Vlan20
description user3
ip address 172.16.20.1 255.255.255.0
ip nat inside
interface Vlan30
description user4
ip address 172.16.30.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
no ip http secure-server
ip nat inside source list NAT interface FastEthernet4 overload
ip access-list extended NAT
permit ip 172.16.0.0 0.0.255.255 any log ACCESS-GRANTED
deny   ip any any log ACCESS-DENIED
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
no modem enable
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
scheduler max-task-time 5000
end
SWITCH CONFIG (WS-C2960-8TC-L):
Current configuration : 1536 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname x
aaa new-model
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
description LINK TO PC1
switchport mode access
switchport nonegotiate
spanning-tree portfast
interface FastEthernet0/2
description LINK TO ACCESS POINT
switchport trunk native vlan 10
interface FastEthernet0/3
description LINK TO LAB
interface FastEthernet0/4
description LINK TO PC2
interface FastEthernet0/5
description LINK TO LAPTOP
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface GigabitEthernet0/1
description LINK TO ROUTER
interface Vlan1
ip address 172.16.1.2 255.255.255.0
no ip route-cache
ip http server
radius-server source-ports 1645-1646
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 5 15
end
ACCESS POINT CONFIG (AIR-AP1231G-E-K9):
Current configuration : 2267 bytes
version 12.3
no service pad
hostname x
ip subnet-zero
aaa new-model
dot11 vlan-name GUEST_NETWORK vlan 10
dot11 vlan-name WORTEL vlan 1
dot11 ssid GUEST_NETWORK
   vlan 10
   authentication open
   authentication key-management wpa
   mbssid guest-mode
   wpa-psk ascii 7 x
dot11 ssid WORTEL
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 x
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
encryption vlan 10 mode ciphers aes-ccm
encryption vlan 1 mode ciphers aes-ccm
ssid GUEST_NETWORK
ssid WORTEL
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1
no ip route-cache
interface Dot11Radio0.10
encapsulation dot1Q 10 native
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
no ip address
no ip route-cache
speed auto
full-duplex
hold-queue 160 in
interface FastEthernet0.1
no ip route-cache
interface FastEthernet0.10
no ip route-cache
bridge-group 10
interface BVI1
mtu 1514
ip address 172.16.1.3 255.255.255.0
no ip route-cache
ip default-gateway 172.16.1.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
end
1 ACCEPTED SOLUTION
Hall of Fame Community Legend
Try this:
bridge-group 1
3 REPLIES 3
Try this:
bridge-group 1
Highlighted
Beginner
Thanks this did the job.
I think I'd lost the overview..
Thanks for the ratings.
Content for Community-Ad
August's Community Spotlight Awards
