AP 1242 shows WLC's management ip as it's own ip address
Sufian allan
Dear All,
              we are using wism 4404 code 4.2 , we are using this old code becuase of 1250 mesh APs, now when a user connect to our network and he is using intel proset software he can see details of our AP, like mac, type and AP ip address 9 which in this case it the controllers ip address) is there a way we can prevent the ap from showing it?...we will be doing an upgrade to 7.0.230 soon. will the upgrade takes care of this problem or there is a way to fix it.
thanks a lot you guys
5 Replies 5
Scott Fella
Disable aironet ie in the WLAN SSID advanced tab. That should do it.
-Scott
Leo Laohoo
Go to 7.0.235.0 instead.
Sufian allan
Thanks guys for the quick reply,
i disabled the Aironet IE for the ssid, and only the AP name disappeard but not the IP address, also we have a teat controller that runs code 7.0.230 and its doing the same thing, were i can see the ip address , but not the AP name.
any fix for this.?
Thanks and regards.
is the issue specific to guest wlan using anchor wlc or on all ssids.
Sufian allan
          Its for all SSIDs
