511
Beginner
AP 1572 EAC LWAPP to autonomous conversion problem
Hello community,
I have two 1572eac outdoor Access points and I want to configure them as a bridge between to buildings. Both of them are booting a LWAPP-Image, but I want them to be autonomous.
Directory of flash:/
2    -rwx  64        <date>               sensord_CSPRNG0
3    -rwx  251       <date>               mesh_port_cfg.txt
4    -rwx  278       <date>               info
5    drwx  960       <date>               c1570-k9w8-mx.153-3.JC
22   -rwx  6168      <date>               private-multiple-fs
23   drwx  960       <date>               c1570-k9w7-mx.153-3.JC
232  -rwx  0         <date>               config.txt
233  drwx  0         <date>               configs
As you can see there are two images in the flash of the access point. One for LWAPP and an IOS-Image. When I try to boot the IOS-Image the process fails and a message appears that the ap isn't able to load the firmware of the radio interfaces.
*Mar  1 00:00:17.955: %DOT11-4-LOADING_RADIO: Interface Dot11Radio0, loading the radio firmware (ram:)
*Mar  1 00:00:17.959: %DOT11-2-RESET_RADIO: Restarting Radio interface Dot11Radio0 due to get code failed: firmware file not found
*Mar  1 00:00:17.959: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to
*Mar  1 00:00:17.959: %SYS-5-RELOAD: Reload requested by Init. Reload Reason
Radio FW image download failed ....
Next, I downloaded the newest TAR-File from Cisco and copied it with TFTP on the access point.
After the copy process I booted the ap with the command ap: boot (forgot to unset boot) and he boots the lwapp-Image. I saw my failure and interrupted the boot process to execute the command: ap: boot flash:c1570-k9w7-mx.153-3.JD/c1570-k9w7-mx.153-3.JD
The ap boots but he cannot find the files for the Radio interfaces
Copying radio files from flash: to ram:
%Error opening flash:c1570-k9w7-mx.153-3.JD/c1570-k9w7-mx.153-3.JDL2.bin (No such file or directory)
%Error opening flash:c1570-k9w7-mx.153-3.JD/c1570-k9w7-mx.153-3.JDP2.bin (No such file or directory)
Uncompressing radio files...
File not found: flash:c1570-k9w7-mx.153-3.JD/c1570-k9w7-mx.153-3.JD8004.img
File not found: flash:c1570-k9w7-mx.153-3.JD/c1570-k9w7-mx.153-3.JDL5.bin
File not found: flash:c1570-k9w7-mx.153-3.JD/c1570-k9w7-mx.153-3.JDP5.bin
File not found: flash:c1570-k9w7-mx.153-3.JD/c1570-k9w7-mx.153-3.JD8006.img
...done Initializing flashfs.
Radio0  present 8764 8000 0 A8000000 A8010000 0
*Mar  1 00:00:16.579: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar  1 00:00:17.959: %SYS-5-RELOAD: Reload requested by Init. Reload Reason:
IOS Bootloader - Starting System.
So, is my approach wrong or did I miss something?
And there is something strange. The Flash contains files like These:
ap: dir flash:c1570-k9w7-mx.153-3.JD/
Directory of flash:c1570-k9w7-mx.153-3.JD//
238  drwx  64        <date>               html
432  -rwx  9283043   <date>               c1570-k9w7-mx.153-3.JD
433  -rwx  15376     <date>               c1570_avr.img
434  -rwx  587007    <date>               8006.img
435  -rwx  569235    <date>               8004.img
436  -rwx  11680     <date>               L2.bin
437  -rwx  3811      <date>               L5.bin
438  -rwx  44384     <date>               P2.bin
439  -rwx  18745     <date>               P5.bin
440  -rwx  278       <date>               info
441  -rwx  32494     <date>               file_hashes
442  -rwx  141       <date>               final_hash
443  -rwx  513       <date>               final_hash.sig
444  -rwx  1375      <date>               img_sign_rel.cert
445  -rwx  1371      <date>               img_sign_rel_sha2.cert
6319104 bytes available (34839552 bytes used)
And in the error message the software is looking for these files:
Is there a naming problem or did I something wrong with the boot command?
Thanks for your help.
Daniel
3 REPLIES 3
VIP Mentor
I did this conversion using
I did this conversion using c1570-k9w7-tar.153-3.JBB4.tar (sometime back)
See if that works
Rasika
*** Pls rate all useful responses ***
Highlighted
Beginner
Thanks Rasika for your reply,
Thanks Rasika for your reply, I will try it on monday and will post results.
Daniel
Beginner
Hello Rasika,
Hello Rasika,
sorry for my very late response.
I found a way to bring the bridge up with the correct image.
So I interrupted the boot process and deleted the complete lwapp-image from flash. Then I cleared the boot variable of the ap, so the ap will boot with the first image, which he finds in flash.
Finally the AP boots the coorect image without any error messages of missing files.
Thank you for your help.
Best regards,
Daniel
Content for Community-Ad
August's Community Spotlight Awards
