08-12-2019 11:53 AM - edited 07-05-2021 10:50 AM
When I try set up APs 1832i in Sensor AP mode I have an error - WSA must be enabled before converting an Access Point to Sensor mode. What its mean?
With APs 1600 and 1700 I hadn't this issue.
Thanks in advance.
Solved! Go to Solution.
08-12-2019 12:24 PM
Sensor mode for x8xx APs is intended to use with DNA Assurance. This is a new solution for network monitoring with the AP sending monitoring data to DNA directly.
You need to have the WLC as a fabric on the DNA Center, then, you can see the stats on the DNA assurance page.
-If I helped you somehow, please, rate it as useful.-
08-12-2019 12:24 PM
08-12-2019 02:22 PM
08-14-2019 03:15 AM
