Cisco announces new innovations in SD-WAN, ISRs, SD-WAN Services, and Catalyst 9000 Series switches
1467
Beginner
AP 2802 does not pass u-boot - image problems
AP2802 will not pass u-boot. Seems there are some image problems.
The AP is suppose to have lightweight image.
Any suggestions will be appreciated.
BootROM - 1.78
Booting from SPI flash, Secure mode
BootROM: RSA Public key verification PASSED
BootROM: CSK block signature verification PASSED
BootROM: Boot header signature verification PASSED
BootROM: Box ID verification PASSED
BootROM: JTAG is disabled
General initialization - Version: 1.0.0
Detected Device ID 6920
Master bootloder version 1.14
High speed PHY - Version: 2.0
BoardId = 0x21board SerDes lanes topology details:
| Lane # | Speed| Type |
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
:** Link is Gen1, check the EP capability
PCIe, Idx 1: Link upgraded to Gen2 based on client cpabilities
PCIe, Idx 2: Link upgraded to Gen2 based on client cpabilities
High speed PHY - Ended Successfully
DDR4 Training Sequence - Ver TIP-0.23.(Sublib 0.8)0
DDR4 Training Sequence - Switching XBAR Window to FastPath Window
DDR4 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
BootROM: Boot image signature verification PASSED
____ _
/ ___|(_) ___ ___ ___
| | | |/ __| / __|/ _ \
| |___ | |\__ \| (__| (_) |
\____||_||___/ \___|\___/
_ _ ____ _
| | | | | __ ) ___ ___ | |_
| | | |___| _ \ / _ \ / _ \| __|
| |_| |___| |_) | (_) | (_) | |_
\___/ |____/ \___/ \___/ \__|
** LOADER **
U-Boot 2013.01-g729a7b4 (Dec 05 2016 - 23:44:32) SDK version: 2015_T2.0p10
Board: Barbados-2K
SoC: MV88F6920 Rev A1
running 2 CPUs
CPU: ARM Cortex A9 MPCore (Rev 1) LE
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DDR4 32 Bit Width,FastPath Memory Access, DLB Enabled, ECC Disabled
DRAM: 1 GiB
NAND: 256 MiB
SF: Detected N25Q32A with page size 64 KiB, total 4 MiB
PCI-e 1 (IF 0 - bus 0) Root Complex Interface, Detected Link X1, GEN 2.0
PCI-e 2 (IF 1 - bus 1) Root Complex Interface, Detected Link X1, GEN 2.0
Map: Code: 0x3fedc000:0x3ffad730
BSS: 0x3ffef1d4
Stack: 0x3f9cbf20
Heap: 0x3f9cc000:0x3fedc000
U-Boot Environment: 0x00100000:0x00110000 (SPI)
Board configuration:
| port | Interface | PHY address |
| egiga1 | SGMII | 0x01 |
| egiga2 | SGMII | 0x00 |
Net: , egiga1, egiga2 [PRIME]
Hit ESC key to stop autoboot: 0
Creating 1 MTD partitions on "nand0":
0x000000200000-0x000010000000 : "mtd=2"
UBI: attaching mtd1 to ubi0
UBIFS: mounted UBI device 0, volume 1, name "part2"
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0xfffcf102, read 0xc492d1ca
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 162:73472
UBIFS error (pid 0): ubifs_read_node: expected node type 2
UBIFS error (pid 0): ubifs_finddir: cannot find next direntry, error -117
part2/part.bin not found!
ubifsload - load file from an UBIFS filesystem
Usage:
ubifsload <addr> <filename> [bytes]
- load file 'filename' to address 'addr'
Unable to load image part2/part.bin
Trying alternate partition part1
UBIFS: mounted UBI device 0, volume 0, name "part1"
Loading file 'part1/part.bin' to addr 0x02000000 with size 18653031 (0x011c9f67)...
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0xb859bcba, read 0xe56befd9
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 11:0
UBIFS error (pid 0): ubifs_read_node: expected node type 1
UBIFS error (pid 0): do_readpage: cannot read page 0 of inode 66, error -117
Error reading file 'part1/part.bin'
part1/part.bin not found!
Checking image signing.
Image signing verification failure(-2), not allowed to run...
Giving up. Rebooting...
resetting ...
1 ACCEPTED SOLUTION
Hall of Fame Guru
Re: AP 2802 does not pass u-boot - image problems
Contact TAC and get the AP replaced or TAC can load the firmware image via console.
Hall of Fame Guru
While in u-boot, please post the complete output to the command "pri".
Beginner
u-boot>> pri
BOOT=part2
CASset=max
ENABLE_BREAK=1
FACTORY_RESET=0
MALLOC_len=5
MANUAL_BOOT=0
MEMORY_DEBUG=0
MPmode=SMP
autoload=yes
baudrate=9600
bootcmd=nandboot
bootdelay=3
cacheShare=no
disaMvPnp=no
eeeEnable=no
enaClockGating=no
enaCpuStream=no
enaFPU=yes
enaMonExt=no
enaWrAllo=no
eth1addr=00:50:43:39:61:7b
eth1mtu=1500
eth2addr=00:50:43:39:fd:7b
eth2mtu=1500
ethact=egiga2
ethaddr=00:50:43:fd:61:7b
ethmtu=1500
ethprime=egiga2
fdt_high=0x2000000
image_name=part.bin
initrd_high=0xffffffff
limit_dram_size=yes
loadaddr=0x02000000
loads_echo=0
mtddevname=fs
mtdids=nand0=armada-nand
mtdparts=mtdparts=armada-nand:1m(oops),1m(reserved),-(fs)
nandEcc=nfcConfig=4bitecc
netretry=yes
partition=nand0,2
pcieTune=no
pexMode=RC
stderr=serial
stdin=serial
stdout=serial
yuk_ethaddr=00:00:00:EE:51:81
Environment size: 877/65532 bytes
u-boot>>
Hall of Fame Guru
Try this:
setenv bootfile board_init_barbados2k.img
saveenv
boot
Beginner
Thank you for your suggestion.
It did not help...
BootROM - 1.78
| 1 | 0 | SGMII1 |
| 2 | 5 | PCIe1 |
| 4 | 5 | PCIe2 |
| 5 | 0 | SGMII2 |
____ _
| | | |/ __| / __|/ _ \
_ _ ____ _
| | | | | __ ) ___ ___ | |_
** LOADER **
Board: Barbados-2K
running 2 CPUs
CPU 0
CPU @ 1800 [MHz]
L2 @ 900 [MHz]
TClock @ 250 [MHz]
DDR4 @ 900 [MHz]
DRAM: 1 GiB
NAND: 256 MiB
BSS: 0x3ffef1d4
Stack: 0x3f9cbf20
Loading file 'part2/part.bin' to addr 0x02000000 with size 28260381 (0x01af381d)...
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0xcabd32cd, read 0xd979ca6b
UBIFS error (pid 0): ubifs_check_node: bad node at LEB 168:57616
UBIFS error (pid 0): do_readpage: cannot read page 0 of inode 75, error -117
Error reading file 'part2/part.bin'
UBIFS error (pid 0): ubifs_check_node: bad CRC: calculated 0xc3fb9270, read 0xe56befd9
resetting ...
u-boot>> pri
BOOT=part2
CASset=max
ENABLE_BREAK=1
FACTORY_RESET=0
MALLOC_len=5
MANUAL_BOOT=0
MEMORY_DEBUG=0
MPmode=SMP
autoload=yes
baudrate=9600
bootcmd=nandboot
bootdelay=3
bootfile=board_init_barbados2k.img
cacheShare=no
disaMvPnp=no
eeeEnable=no
enaClockGating=no
enaCpuStream=no
enaFPU=yes
enaMonExt=no
enaWrAllo=no
eth1mtu=1500
eth2mtu=1500
ethact=egiga2
ethmtu=1500
ethprime=egiga2
fdt_high=0x2000000
image_name=part.bin
limit_dram_size=yes
loadaddr=0x02000000
loads_echo=0
mtddevname=fs
netretry=yes
partition=nand0,2
pcieTune=no
pexMode=RC
stderr=serial
stdin=serial
stdout=serial
Environment size: 914/65532 bytes
u-boot>>
Hall of Fame Guru
Content for Community-Ad
Blog-Cisco Community Designated VIP Class of 2019
