05-28-2019 12:49 AM - edited 07-05-2021 10:28 AM
Hi Sir
I have a problem that 3702I not join 2504WLC
3702I ver : C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JC15
WLC ver : 8.2
here is my error log
*May 27 09:22:41.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.1.10 peer_port: 5246
*May 27 09:22:41.287: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.1.10 peer_port: 5246
*May 27 09:22:41.287: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.1.10
*May 27 09:22:59.351: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.1.10:5246
*May 27 09:22:59.431: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*May 27 09:22:59.431: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*May 27 09:22:59.435: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 09:22:59.463: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*May 27 09:23:00.435: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 09:23:00.463: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*May 27 09:23:00.471: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*May 27 09:23:01.455: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 09:23:01.463: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*May 27 09:23:01.507: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*May 27 09:23:01.515: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*May 27 09:23:01.523: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*May 27 09:23:02.507: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*May 27 09:23:02.515: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*May 27 09:23:02.543: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*May 27 09:23:03.543: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*May 27 09:23:09.463: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
please help me to slove
05-28-2019 03:53 AM
Hii there
Which version of WLC 8.2 ?
Version 15.3(3)JC15 requires WLC 8.2.170.0 or higher
reference: wireless compatibility matrix
05-28-2019 07:07 PM
05-28-2019 08:23 PM
WLC
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.170.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 20.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_0f:79:c4
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 192.168.1.10
IPv6 Address..................................... ::
Last Reset....................................... Software reset
System Up Time................................... 1 days 18 hrs 13 mins 4 secs
System Timezone Location......................... (GMT +8:00) HongKong, Bejing, Chongquing
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... TW - Taiwan
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +38 C
External Temperature............................. +40 C
Fan Status....................................... 96 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 50:F7:22:0F:79:C0
Maximum number of APs supported.................. 75
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
AP 3702I
APa89d.218a.5ed0>show version
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JC15, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 07-Jun-18 16:43 by prod_rel_team
ROM: Bootstrap program is C3700 boot loader
BOOTLDR: C3700 Boot Loader (AP3G2-BOOT-M) LoaderVersion 15.2(4)JB, RELEASE SOFTWARE (fc1)
APa89d.218a.5ed0 uptime is 18 hours, 41 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JC15/ap3g2-k9w8-xx.153-3.JC15"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP3702I-UXK9 (PowerPC) processor (revision A0) with 376814K/134656K bytes of memory.
Processor board ID FCW1904NW73
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.2.170.0
Access Point Type: World Mode
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A8:9D:21:8A:5E:D0
Part Number : 73-15243-01
PCB Serial Number : FOC19036U3T
Top Assembly Part Number : 068-100398-01
Top Assembly Serial Number : FCW1904NW73
Top Revision Number : A0
Product/Model Number : AIR-AP3702I-UXK9
Configuration register is 0xF
05-28-2019 11:38 PM
05-30-2019 07:26 PM
(Cisco Controller) >show time
Time............................................. Fri May 31 10:26:00 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT +8:00) HongKong, Bejing, Chongquing
NTP Servers
NTP Polling Interval......................... 3600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 192.168.1.11 In Progress AUTH DISABLED
05-31-2019 07:06 AM
05-31-2019 07:19 AM
06-02-2019 10:39 PM
Yes,sir.I have already AP in WLC
When I clean the flash image and reload.
The AP is controllered.
Thanks so much!!
