AP-3802 dont'join ME-3802
I have an AP-ME 3802 with firmware 8.3.150.0
and 1 AP with firmware 8.3.111.0
I have the file AIR-AP3800-K9-ME-8-3-150-0.tar
once the .tar file has been downloaded to the AP with the command
archive download-sw / reload tftp: // <<ip_tftp_server>> / <<image>> .tar
what is the next step to start the AP with firmware 8.3.150.0 and allow the AP to join the ME-AP ???
aha.... the space!
tftp: //10.96.28.177/AIR-AP3800-K9-ME-8-3-150-0.tar
tftp://10.96.28.177/AIR-AP3800-K9-ME-8-3-150-0.tar
good to hear you found the error
13 Replies 13
pieterh
read the ME deployment guide
though this document reads 8.3.120 it will also be valid for 8.3.150
basically "archive download-sw" is the wrong command, to install the ME image you should use
AP#ap-type mobility-express tftp://<TFTP Server IP>/<path to tar file>
I do not have to install the ME firmware but to upgrade the AP which then has to join the AP-ME.
this command
AP # ap-type mobility-express tftp: // <TFTP Server IP> / <path to tar file>
I transform the AP into ME-AP
the Ap with firmware 8.3.111.0 dont'join the ME-AP
[* 12/05/2019 20: 18: 28.0486] CAPWAP State: Join
[* 12/05/2019 20: 18: 28.0524] Sending Join request to 10.96.28.3 through port 5256
[* 12/05/2019 20: 18: 28.0548] Join Response from 10.96.28.3
[* 12/05/2019 20: 18: 28.1264] HW CAPWAP tunnel is ADDED
[* 12/05/2019 20: 18: 28.1394]
[* 12/05/2019 20: 18: 28.1394] CAPWAP State: Image Data
[* 12/05/2019 20: 18: 28.1693] do PRECHECK, part2 is active part
[* 12/05/2019 20: 18: 28.2993] AC rejected join request [17], try again later.
[* 12/05/2019 20: 18: 28.2993] Controller rejected image download.Check if TFTP server configured on ME WLC or maximum concurrent download limit has reached
i try also to upgrade AP with command
archive download-sw /no-reload tftp://10.96.28.177/ap3g3
or
archive download-sw /no-reload tftp://10.96.28.177/AIR-AP3800-K9-ME-8-3-150-0.tar
but
Image downloaded, writing to flash...
do PREDOWNLOAD, part1 is active part
upgrade.sh: Error: TAR_READ_ERROR, not updating ubi vol
+ do_upgrade PREDOWNLOAD
+ [ ! -r /tmp/part.tar ]
+ [ 1 -lt 3 ]
+ local base_vol=/dev/ubivol
+ local action=PREDOWNLOAD
+ cat /MERAKI_BOARD
+ local board=barbados
+ get_activepart
+ get_activepart_real
+ cat /proc/cmdline
+ local kcmdline=console=ttyS0,9600 activepart=part1 activeboot=0 bootver=0x11e boardid=0x25 nss_emac_map=0x3 wired0=0 phy0=mv2010 nfcConfig=4bitecc mtdparts=armada-nand:1m(oops),1m(reserved),-(fs) ubi.mtd=fs wired1=1 phy1=mvl
+ echo console=ttyS0,9600
+ grep activepart
+ echo activepart=part1
+ grep activepart
+ awk -F= {print $2}
+ echo activeboot=0
+ grep activepart
+ echo bootver=0x11e
+ grep activepart
+ echo boardid=0x25
+ grep activepart
+ echo nss_emac_map=0x3
+ grep activepart
+ grep activepart
+ echo wired0=0
+ echo phy0=mv2010+ grep activepart
+ echo nfcConfig=4bitecc
+ grep activepart
+ + grepecho activepart mtdparts=armada-nand:1m(oops),1m(reserved),-(fs)
+ echo ubi.mtd=fs
+ grep activepart
+ echo wired1=1
+ grep activepart
+ echo phy1=mvl
+ grep activepart
+ local part_active=part1
+ [ part1 != part1 -a part1 != part2 ]
+ echo part1
+ local active_part=part1
+ get_alternateboot part1
+ [ part1 == part2 ]
+ echo part2
+ local part_to_upgrade=part2
+ local eff_upgrade_master=false
+ local tftp_image_vers=
+ local skip_img_sign_verify=false
+ local skip_boot_upgrade=false
+ + echotr
, \n
+ echo dangerous 21030
+ sync
+ cd /tmp
+ [ barbados == barbados ]
+ tar -xf /tmp/part.tar info.ver info btldr.img setenv.gz
+ [ PREDOWNLOAD == CHECK_ME ]
+ get_capwap_version
+ [ 0 -lt 1 ]
+ local version_file=/tmp/info.ver
+ [ -f /tmp/info.ver ]
+ echo
+ local capwap_version=
+ /usr/sbin/getoffset /tmp/part.tar part.bin
+ local fileoffset=Filename Tar_Read_Error Offset 0 Length 0 Errorcode 9
+ echo Filename Tar_Read_Error Offset 0 Length 0 Errorcode 9
+ cut -f4 -d
+ local partfileoffset=0
+ cut -f6 -d
+ local partfilesize=0
+ cut -f8 -d
+ local errorcode=9
+ [[ 9 -ne 0 ]]
+ reportupdatestatus 9
+ loudlog Error: TAR_READ_ERROR, not updating ubi vol
+ logger -p 0 -t upgrade Error: TAR_READ_ERROR, not updating ubi vol
+ echo upgrade.sh: Error: TAR_READ_ERROR, not updating ubi vol
+ return 9
+ status=9
+ set +x
Error: '/etc/capwap-upgrade.sh PREDOWNLOAD' failure.
Based on the filename you have the wrong file. The .tar file is to be used for the migration, which means you need to use the command: ap-type mobility-express tftp://<TFTP Server IP>/<path to tar file>
Otherwise the file: AIR-AP3800-K9-ME-8-3-150-0.zip with the commands you tried before.
See here: https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83mr5.html
ok well, i try with  archive download-sw /no-reload tftp://10.96.28.177/AIR-AP3800-K9-ME-8-3-150-0.zip
but
######################################################################## 100.0%
upgrade.sh: Error: image not found.
+ loudlog Error: image not found.
+ logger -p 0 -t upgrade Error: image not found.
+ echo upgrade.sh: Error: image not found.
+ return 1
+ status=1
+ set +x
Can you show the output of 'show version'? Depending on that output, you have to use a different image.
could you tell me how to resolve this issue? i have same issue: Error: TAR_READ_ERROR, not updating ubi vol
see response later in this thread :
11-12-2019 03:34 PM
ehm after, try and re-try and retray   this commando
     ap-type mobility-express tftp://10.96.28.177/AIR-AP3800-K9-ME-8-3-150-0.tar
now the firmware is update and the AP join the ctrl-ME! alleluja
then you have the wrong firmware
AIR-AP3800-K9-ME-8-3-150-0.tar -> this is the ME-image
But.... also with  two AP's with ME image -> one AP is the master and the other can join
the firmware is correct, because 5 more APs are working
the firmware is correct, because 5 more APs are working.
also using this ap-type mobility-express tftp: //10.96.28.177/AIR-AP3800-K9-ME-8-3-150-0.tar
and making the AP (ME), the firmware is not loaded in the correct manner
thx!!!
aha.... the space!
