Highlighted
Beginner
Ap AIR-CAP3602I-A-K9 Not able to Join in Controller
Berofe some day my AP AIR-CAP3602I-A-K9 is not booting up so we rasied an RMA for that part. So we recived the replacment against same but we try to join Ap in controller but we are getting error. Can any once help us to resolve same.
We tried with below commands
lwapp ap controller ip
lwapp ap ip address
2 REPLIES 2
Highlighted
VIP Mentor
Hi Sunil,
Your AP has come with mesh image & not proper local mode image. Below log message indicate that.
flash:/mesh_start_cfg.txt: No such file or directoryThe filesystem containing the variables may not be initialized yet.
*Oct 23 10:32:20.611: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Oct 23 10:32:20.611: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Oct 23 10:32:20.611: %MESH-6-LINK_UPDOWN: Mesh station 0006.f64d.6cb3 link Down
If that is the case you have to add AP ethernet mac address onto WLC mac-filter data base (under Security -> MAC filtering)  & then allow AP to register in mesh mode. You can add this entry via WLC CLI as well. Here is the full CLI command syntax
(WLC) >config macfilter add [interface name] [description] [Client IP address]
In your case you can do like this.
(WLC) >config macfilter add 00:06:F6:4D:6C:B3 0 management
Once you do this your AP should register to WLC in mesh mode. Then  you can convert it to local mode via WLC GUI or CLI. Here is the CLI way of doing it
(WLC) >config ap mode local submode none
Rasika
***** Pls rate all useful responses *****
Highlighted
Issue has been resolved after adding the AP Mac id in Security ->AP Policy.
Content for Community-Ad
