04-08-2015 01:59 PM - edited 07-05-2021 02:52 AM
Hello Experts,
Wireless controller summary page displays the AP & radio 0 & 1 up/down status.
Is there an easy way to find the AP which is affected?
Right now I have to go through all the AP's and see the status.
Your idea & suggestions will be highly appreciated.
Thanks in advance,
04-08-2015 03:11 PM
I can think of three possible solutions for this:
1. If all of your AP's have CleanAir enabled you can filter on "CleanAir Oper Status" in the web GUI
2. Use the following command on the CLI:
(WLC) >grep include "DOWN" "show advanced 802.11a sum"
3. Use Cisco Prime Infrastructure as monitoring tooling
Please rate useful posts :-)
04-08-2015 05:31 PM
Thank you very much Freerk,
In my environment we have many APs 1242 model so clean air is not available.
and this is the output of the command & one AP radio1 is down.
Thanks again in advance for any explanation. what I understand is this commands output will also depend on clean air enabled APs only, please correct me if, I am right.
04-09-2015 02:23 PM
The command is case-sensitive, so it needs to be "DOWN" instead of "down". You don't need CleanAir access-points for getting the correct output with this command.
04-10-2015 11:11 AM
Thank you very much Freerk!!
It worked and very useful command.
Thanks!!
04-09-2015 11:03 PM
HI Lenka,
As per your screenshot, your 5 APs Slot1 (5Ghz) is down.
and you want to know that which AP having this problem right ?
Go to Wireless > Access Points>Radios >802.11a
Here you will see the complete list of APs with Radio status.
See the screenshot:
Don't forget to rate helpful posts
