05-15-2014 05:35 AM - edited 07-05-2021 12:50 AM
When an access points doesn't find a controller it gets always a new IP address from DHCP server.
Does anyone know, why?
thanks
05-15-2014 06:37 AM
If it is a Cisco IOS DHCP server, it is always do that & that is normal.
Rasika
**** Pls rate all useful responses ****
05-15-2014 06:41 AM
Hi Rasika,
thanks for your answer.
It is a Microsoft DHCP server.
regards
Martin
05-19-2014 10:56 AM
you can fixed your ip in the DHCP server configuration in AD and that will resolve your issue .
**********Do rate Helpful posts*********
08-04-2014 03:02 AM
From what I know this is to do with DHCP option 60 and 43.Normally when APs request for IP address, DHCP Server also returns the management IP Address of WLC if the VCI matches.
If the VCI sent by the AP does not match with the one configured under DHCP for that particulart AP type, the DHCP will never return the WLC IP and hence AP can not find the controller.And the AP keeps sending DHCP Req and sometimes end up getting two IP addresses!
So may be you can check VCI on DHCP server for that AP model.
Let me know.
Cheers
