10-31-2018 08:58 AM - edited 07-05-2021 09:23 AM
Testing AP Image Predownload (two access points 3502i & 3702i. After upgrading controller code to 8.5.135.0 and issuing the ap image predownload all primary command. I notice that the 3502i shows both the new primary and backup image. But the 3702i only shows the new primary:
Please see the attached show ap image all attached. Why would that be? Thanks
10-31-2018 12:50 PM
Did 3702i had 8.3.x image before hand ?
If you have additional 3702i, pls test it with that & see you see similar behavior
Rasika
11-01-2018 06:16 AM
Rasika
Yes it had 8.3.133.0 on it. Thanks for reply!
10-31-2018 03:03 PM
This is the new "norm" for the 2700/3700.
The AP can only store two IOS directories (instead of three).
11-01-2018 06:21 AM
Leo,
I'm only seeing one image the primary, under backup I see 0.0.0.0. when I issue the show ap image all.
Thank You
11-01-2018 04:39 PM
11-07-2018 08:37 AM
There is often a recovery image there meaning only enough space for 1 IOS.
This change is detailed in: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvk71897 - AP will delete backup image if free flash size below 10Mb and rcv image present.
FYI this caused another (mostly cosmetic) bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvf71263
Depending on new and old image size deleting the recovery image may allow the AP to hold new and backup image.
Note the recovery image won't show on the WLC.
12-19-2019 03:39 AM
12-19-2019 01:08 PM
