Community Live- Understanding How Multicast Works with Cisco
7394
Highlighted
Beginner
AP Software being upgraded, please try again later.
After upgrading WLC to version 7.2.111.3 needed to update webauth certificate on the controller. The cert upload is unsuccessfully with error message shows that AP software being upgraded, pls try again later.
Tried to reboot WLC from CLI or GUI with no success.
Anyone experience the same issue and what would be work around?
Everyone's tags (6)
9 REPLIES 9
Hall of Fame Master
Re: AP Software being upgraded, please try again later.
I had that issue with another code version so I left it for a couple hours and tried it again. I still got the error because I was upgrading and it failed in the middle. So after a few hours, I just unplugged the power and powered the WLC back up and performed the upgrade again.
-Scott
Beginner
The code upgrade went OK, all APs have correct code version just the WLC reporting that cannot reboot.
I have two WLCs - one is close to me another 2hrs plain flight away. I rebooted the frist one ok and now have no error message but wonderign about the other one.
Beginner
I know this is a bit late -
I know this is a bit late - but might be useful for someone else.
I had the same issue. I rebooted all the access points. No luck
However   after using the "reset system forced" It came back and upgraded the access points normally.
Hello Martin, yes some of the
Hello Martin, yes some of the TAC engineer are aware of this command some of them not. This command is a bit mysterious to me as it cannot be found in the official Cisco command reference book.  Anyhow good to know this command exists and it can be used for example when "ap predownload image all" hangs and cannot be completed for some reason.  My reference TAC case 629991017 : not able to remotely reset system after IOS code upgrade. Thank you
Beginner
I found it was related to a
I found it was related to a bug id # SCuh25790
See link http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn74mr01.html
Beginner
Thanks Martin, the forced
Thanks Martin, the forced option allowed me to bounce the WLC. I had the same issue as the title of the OP.
Are none of the AP joined to 7.2 or APs bouncing back and fourth or false positive.
unplug the power, boot with secondary image, update cert, code.
Beginner
I had a similar issue. For me
I had a similar issue. For me helped moving all the access points to a different controller and then "reset system" worked.
Karel
Beginner
Hi,I have one solution. If
I have one solution. If you are using WISM2 or module base controller (not standalone controller) you can go to chasis and shut down the power to the WLC modul by using "no power module xx" to power off the WLC and then type "power module xx" to power up the WLC.
Content for Community-Ad
August's Community Spotlight Awards
