Highlighted
AP1552WU version AIR-OS
Someone knows with what versions of OS the Access Point AP1552WU is compatible in the WLC.
Greetings.
Everyone's tags (1)
4 REPLIES 4
Highlighted
Re: AP1552WU version AIR-OS
 This is not a matter of IOS version but IOS type. If the IOS is autonomous not way it is going to join a WLC.  It must be running a capwap image.
-If I helped you somehow, please, rate it as useful.-
Highlighted
Hi Flavio,
It seems that my query was not understood.
In the Wireless compatibility matrix, this Access Point model (1552WU) does not appear, given that I do not know what version of OS I should have in my WLC.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Greetings.
Greetings.
Highlighted
VIP Advocate
Good question, I think the last supported version is probably 8.5.x.
But, if it only contains 64 MB memory, then the last supported version is 8.3.x.
Content for Community-Ad
August's Community Spotlight Awards
