06-28-2019 02:46 AM - edited 07-05-2021 10:37 AM
I have to make a Wi-Fi implementation survey, my client wants Cisco AP1852i but i can't find the datasheet of this model.
Is it the same as for Cisco AP 1850 series ? I don't see the difference.
I need to radio pattern.
Thank you for your future help.
Solved! Go to Solution.
06-28-2019 03:55 AM
Using the same dipole antenna type .. I imagine the pattern would be the same.
06-28-2019 02:48 AM
06-28-2019 02:55 AM
So the radio patterns are the same ?
06-28-2019 03:55 AM
06-28-2019 04:14 AM
Ok thank you for your answer :)
