11-14-2019 12:53 AM - edited 07-05-2021 11:18 AM
Hi , I was more concerned feature and functional AP is disable ?
access switch and AP show 29.9watts negotiated.
WLC5520 version 8.8.100.0
11-14-2019 01:01 AM
It need 30-31watt to work with full functionality.
you can use these to power it on with full power:
Paste the out form swicth:
show power inline
Dont forget to rate helpful posts
11-14-2019 01:04 AM
More info:
The AP-4800 supports a local DC power supply Cisco Part Number AIR-PWR-50 and will draw 28.7W
When using a Power over Ethernet (PoE) source, for best performance an 802.3bt / universal (uPoE) source is best. Any switch supporting Multigigbit (mGig) should be able to supply uPoE over 32W.
The AP-4800 will not function using older 802.3af (15.4W) PoE systems, but will function in a slightly reduced mode (USB power off and limiting the aux port and reducing mGig to GbE rates. This is a very powerful Access Point, we are looking to optimize all features at 30W in a later release, however that has not been committed as of 8.7.
11-14-2019 04:50 AM
