11-07-2011 07:53 PM - edited 07-03-2021 09:02 PM
We have many MacBook pros that are having a hard time staying connected on wireless. Often times a user can be connected for only minutes at a time. Our wireless environment consists of 1142s and 3502 series access points. We use WPA2 Enterprise for authentication via ACS server 5.x.
The Windows 7 machines usually never have an issue. Can someone please provide some insight.?
*we use Lion OSX on our Macs.
This Discussion has been converted into a Document:- https://supportforums.cisco.com/docs/DOC-26228
Solved! Go to Solution.
07-26-2013 04:59 AM
It affects 2 iPhone 4S's neither jail broken
But I think I can see your point about it being an issue with the iPhone but while in work there is no issue and that's with the same heads but using a wireless controller and lightweight heads
09-20-2013 06:28 PM
I am facing the isue with dell laptops. Same model with same version would work absolutely fine. but few of them wont. They will connect work for a minute and then drop off. they seem to be little better while connecting using webauthentication on same Wifi network on Guest SSID.
If I modify wifi properties of the latop to use on 802.11a only. it resolves issue but the problem but since user use same device at home or while travelling they would not like this to be done everytime.
Aijaz
09-21-2013 08:04 AM
You should start your own post.
