1734
Highlighted
Beginner
Apple wireless clients authenticated but show no username in WLC
Running 7.0.220. There are several 'unknown' users every day reported in WCS. Investigating the connections on the WLC I find the clients are in a run state and passing traffic but there is no username listed on the client detail. (hence the unknown on WCS)
(mcm-189jsoc-wlc1) >show client detail 60:c5:47:07:b6:5a
Client MAC Address............................... 60:c5:47:07:b6:5a
Client Username ................................. N/A
AP MAC Address................................... 00:1e:13:42:16:a0
AP Name.......................................... mcm-208dorm-wap1
Client State..................................... Associated
Client NAC OOB State............................. Access
Wireless LAN Id.................................. 1
BSSID............................................ 00:1e:13:42:16:a0
Connected For ................................... 599 secs
Channel.......................................... 11
Clients in this state are usually Apple products. From initial investigation it looks like the do authenticate with the ACS.
Any ideas for debugs to run, or fixes on the WLC? Perhaps there's a bug on this behavior?
Kyle Morrison
11 REPLIES 11
Hall of Fame Master
Re: Apple wireless clients authenticated but show no username in
So for sure the SSID those clients are connecting on is using 802.1x? Does the username show up in the ACS passed attempt logs?
-Scott
Beginner
Yes the clients are using 802.1x. The username shows up in ACS passed authentication log.
Kyle:
I suppose you are using PEAP or some EAP that utilizes TLS tunnel.
The username that appears is what cold "outer identity" username. This is sent to the AAA server outside the TLS channel and need not to be the correct username although it can be the same. So I think with macBooks the outer identity is empty. But I don't remember if it appears on the WLC as unknown.
For ipad I can see my username explicitly appearing on my WLC which means the outer identity is same asthe correct username.
What mac devices that you use?
You need no debugs. Wireless packet capture while the client is trying to authenticate should be enough to show what outer identity is used.
Amjad
p.s: with windows it depends on the supplicant software if an outer identity can be configured or not.
Rating useful replies is more useful than saying "Thank you"
Hall of Fame Master
I just tested this out and I can see the username in both the ACS 5.2 logs and in the WLC using an iPhone 4 and an iPad.  Maybe look at upgrading to the latest 7.0.x code, as I'm running 7.2.x.
-Scott
Beginner
Thanks for that. I'm at a government institution and upgrading is never an option. I'm going to look a little more into the outside identity thing with the macs.
Hall of Fame Master
Kyle,
You can always open a TAC case and see if there is something with the code you are running.  I have tested many different codes, and I don't remember not seeing a username when using 802.1x on the WLC with your version of code.
-Scott
When the client fails auth then you will see the outer ID. When it passes auth it gets updated with the real ID..
This is how I recalling seeing this ..
Scott can you test this?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Hall of Fame Master
George is funny. But yes I can and have:) my iDevices show up as long as its associated and connected using PEAP 802.1x if it doesn't pass authentication it doesn't show anything. The ACS or radius logs will show the username that fails though.
-Scott
Ok so my thinking is correct then .. I see this with my phones from time to time with unknown or anynomous .. this is a good blog post ..
Hall of Fame Master
Haha... You blog about it George:)
-Scott
Hall of Fame Master
But now I'm on 7.4:) I don't like to download all the time as it messes up my lab:)
-Scott
Content for Community-Ad
August's Community Spotlight Awards
