12-05-2012 07:02 AM - edited 07-03-2021 11:10 PM
Dear Friends,
a week ago I had stable wireless network APs were getting IPS from 6500 series switch (DHCP) but unfortunately some WISM got rebooted and now APs are unable to receive IP address from Core 6500 DHCP, to cater this issue I have another DHCP server configured on windows 2008 i created another subnet and and put APs in that vlan now all APs are are successfully receiving IPS from windows DHCP server I don't know why APs are not able to receive IPs from core 6500 series DHCP.
please advice
Faysal
Solved! Go to Solution.
12-05-2012 07:36 AM
Did the VLAN get removed somewhere? I've seen where VTP pruning pulled a VLAN when an upstream switch was disconnected. So possibly, if the AP VLAN was trunked to the WiSM and the WiSM went away pruning could have kicked in.
If you plug a laptop into the VLAN, does it get an IP address from the 6500?
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
12-05-2012 07:58 AM
ok, so that sounds more like a DHCP issue with the 6500, can you do a show ip binding? make sure the leases aren't exhausted.
I think you can also do a debug dhcp on the sup and get some information out of there as well.
HTH,
Steve
12-05-2012 08:10 AM
No there is not. The AP will do it's DHCP request when it first comes up, which is before it tries to talk to the WLC.
HTH,
Steve
12-05-2012 07:25 AM
The WiSM rebooting is most likely a red-herring as the AP would need to get it's IP prior to contacting the WLC.
If it was just some AP, was there a geographical similarity? i.e. same switch/path to the 6500.
HTH,
Steve
12-05-2012 07:28 AM
Thanks for Reply Stephen
i have two 6500 core switches each has one WISM and and each wism has two controllers i have almost 250 Aps and not a single AP is getting IP from core switch
12-05-2012 07:36 AM
HTH,
Steve
12-05-2012 07:42 AM
You are right its trunked with WISM and vlan is in allowed list when i connect my laptop i dont receive any IP however the controllers are configured with static IPS from the same subnet and ping able from core switch .
12-05-2012 07:43 AM
when i connect AP into same vlan Aps are getting this message:
Mar 1 00:25:38.035: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:25:38.035: %CAPWAP-5-DHCP_RENEW: Could not discover WLC using DHCP IP. Renewing DHCP IP.
*Mar 1 00:25:48.035: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:25:58.035: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:26:08.035: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
*Mar 1 00:26:18.035: %CAPWAP-3-ERRORLOG: Not sending discovery request AP does not have an Ip !!
Not in Bound state.
12-05-2012 07:58 AM
HTH,
Steve
12-05-2012 08:03 AM
it seems to be a DHCP issue Stephen i am away from network right now but when i isues dhow dhcp server command lease, binding, request everthing was ZERO ,
12-05-2012 08:07 AM
is there any settings on WLAN controllers to get an IP for APs from 6500 switch ???
12-05-2012 08:10 AM
HTH,
Steve
12-05-2012 08:13 AM
i am not a wireless expert just managing the network what else could be the reason that DHCP is not working??
12-05-2012 08:31 AM
nothing off the top of my head, but at this point it's not a 'wireless' issue perse, but a network/dhcp issue.
HTH,
Steve
12-05-2012 08:40 AM
Can you post the config of your 6500 ?
__________________________________________________________________________________________
"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
12-05-2012 08:47 AM
Thanks george for stepping up here is DHCP config
ip dhcp excluded-address 10.10.30.1 10.10.30.20
ip dhcp excluded-address 10.10.8.1 10.10.8.10
ip dhcp excluded-address 192.168.10.1 192.168.10.5
ip dhcp excluded-address 10.9.20.1 10.9.20.30
ip dhcp pool vlan_30
network 10.10.30.0 255.255.254.0
default-router 10.10.30.1
option 60 ascii """"""""""""""""""""""""CiscoAPc1250""""""""""""""""""""""""
option 43 hex f110.0a0a.1e0b.0a0a.1e0d.0a0a.1e0f.0a0a.1e11
dns-server 10.10.2.11
lease infinite
ip dhcp pool WiSM1_SP
network 192.168.10.0 255.255.255.248
default-router 192.168.10.1
12-05-2012 08:48 AM
if you need any other info please let me now
