01-16-2020 03:11 AM - edited 07-05-2021 11:33 AM
are WLC 5508 and AIR-CAP1602I-A-K9 compatible with each other?
Solved! Go to Solution.
01-16-2020 03:34 AM
Yes, 5508 support 1602.
View in release notes, because in some version, some APs not supported.
Bellow last version of firmware: 8.5.151.0 ED
The following Cisco AP platforms are supported in this release:
Cisco Aironet 1600 Series Access Points
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn85mr5.html
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future.
Best regards,
Lucas Freitas
01-16-2020 03:34 AM
Best regards,
Lucas Freitas
01-16-2020 03:50 AM
Yes they are.
For more info, Check the compatibility matrix:
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Dont forget to rate helpful posts
01-16-2020 02:47 PM
01-17-2020 03:01 AM
When AP join in WLC, he is download firmware of WLC.
I like to see release notes of version because sometimes Cisco changes support APs depending version.
Best regards,
Lucas Freitas
01-17-2020 04:18 AM
01-19-2020 05:16 AM
