Community Helping Community
103
Beginner
Autonomous 1602e - Radio TX power restricted
I'm running into an issue where I have limited TX power options on the 5ghz radio of a 1602e.  I have 2 APs running the same code (ap1g2-k9w7-mx.152-2.JB2) but with different power options and I'm trying to adjust cell size by reducing TX power. Anyone run into this?  Is there a fix?
AP1 - This one has several options...
AP1#sho controllers dot11radio1
 AMPDU flows in use = 0
interface Dot11Radio1
Radio Griffin 5, Base Address 3c5e.c36e.4cc0, BBlock version 0.00, Software version 4.10.1
Serial number: FOC18500H41
Unused dynamic SQRAM memory: 0x00000704 (1 KB)
Unused dynamic SDRAM memory: 0x00000000 (0 KB)
Number of supported simultaneous BSSID on Dot11Radio1: 16
Carrier Set: Americas (OFDM) (US) (-A)
Uniform Spreading Required: Yes
Configured Frequency: 5765 MHz  Channel 153
Allowed Frequencies: * Dynamic Frequency Selection (DFS) only
         5180( 36)  5200( 40)  5220( 44)  5240( 48) *5260( 52) *5280( 56) *5300( 60) *5320( 64) *5500(100) *5520(104)
        *5540(108) *5560(112) *5580(116) *5660(132) *5680(136) *5700(140)  5745(149)  5765(153)  5785(157)  5805(161)
         5825(165)
Listen Frequencies:
         5180( 36)  5200( 40)  5220( 44)  5240( 48)  5260( 52)  5280( 56)  5300( 60)  5320( 64)  5500(100)  5520(104)
         5540(108)  5560(112)  5580(116)  5600(120)  5620(124)  5640(128)  5660(132)  5680(136)  5700(140)  5745(149)
         5765(153)  5785(157)  5805(161)  5825(165)
DFS Blocked Frequencies: none
Beacon Flags: 0, Interface Flags 20105, Interface Events 0, Mode 9; Beacons are enabled; Probes are enabled
Antenna:                        Rx[a b c ]
                                Tx[a b c  ofdm all]
                                External
                                Gain [Allowed 12, Reported 0, Configured 8, In Use 12]  (dBi x 2)
Configured TxPower:             7 dBm
Allowed Power Levels:           22 19 16 13 10  7  dBm
Allowed Client Power Levels:    22 19 16 13 10  7  dBm
AP2 - This one is limited....
AP2#sho controllers dot11Radio 1
Radio Griffin 5, Base Address 0cf5.a42a.4070, BBlock version 0.00, Software version 4.10.1
Serial number: FOC18401E3T
Configured Frequency: 5180 MHz  Channel 36
         5825(165)
Listen Frequencies:
Antenna:                        Rx[a b c ]
                                Tx[a b c  ofdm all]
                                External
Configured TxPower:             8 dBm
Allowed Power Levels:           14 11  8  dBm
Allowed Client Power Levels:    14 11  8  dBm
1 ACCEPTED SOLUTION
to be expected, the max power
to be expected, the max power is different per channel in 5GHz
take a look here:
http://www.insearchoftech.com/2015/01/22/cisco-wireless-transmit-power-control/
HTH,
Steve
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
2 REPLIES 2
take a look here:
HTH,
Steve
Beginner
Thanks Steve!
Thanks Steve!
Content for Community-Ad
August's Community Spotlight Awards
