Highlighted
Beginner
Autonomous AP client Association showing but not ip resolved to client ip 0.0.0.0 with out key ip resolve to client
MODEL :AIR-CAP702I-N-K9 converted to autonomous AP client Association showing but not resolved ip to  client 0.0.0.0 key howifi@4f
MSNLHO-4F#sh run
Building configuration...
Current configuration : 1931 bytes
! Last configuration change at 22:38:36 UTC Mon Mar 1 1993
version 15.3
no service pad
service password-encryption
hostname TESTLHO-4F
logging rate-limit console 9
enable secret 5 $1$0hQZ$bwaaGRM2lfm7Z/CbW/GA/.
no aaa new-model
no ip source-route
no ip cef
dot11 syslog
dot11 ssid TESTLHO-4F
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 060E0036454800395111
username CISCO password 7 14341B180F0B
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm tkip
ssid TESTLHO-4F
antenna gain 128
packet retries 64 drop-packet
channel 2437
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
ssid TESTLHO-4F
antenna gain 128
peakdetect
no dfs band block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address 0041.d28f.f368
ip address 192.168.5.253 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ip default-gateway 192.168.5.10
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
transport input all
end
3 REPLIES 3
Highlighted
VIP Mentor
HI,
How you configured the switch port where AP is connected!!!
Please paste the switch port confg here.
Don't forget to rate helpful posts
Highlighted
AP connected to unmanaged switch don't have vlans and dhcp server is external only
Highlighted
Run these commands on AP and paste the output here:
debug ip dhcp server events
debug ip dhcp server packets
Content for Community-Ad
