Autonomous AP - Web Authentication
ANDREA GELATI
Hello everybody,
Can I enable a Web Authentication to an external Captive Portal for a specific SSID with autonomous AP without WLC?
I should activate an hot spot service, in order to manage guest/visitor users.
I need to integrate autonomous AP to an external Captive Portal that provides enhanced guest functionality, such as quota time and quota byte session duration, so the AP need to support http redirection for authentication and radius auth, accounting and CoA.
Thanks in advance,
Andrea
3 Accepted Solutions
Scott Fella
This is not really possible. Autonomous for example is not supported with ISE and CoA. The only thing that can be done is really to setup the AP to allow clients on an SSID and then push it through a captive ports appliance/software to perform the captive portal, etc.
-Scott
Abhishek Abhishek
Hello Andrea,
As per your query i can suggest you the following solution-
No i think you can not enable Web Authentication to an external Captive Portal for a specific SSID with autonomous AP without WLC.
The AP does not support http redirection for authentication and radius auth, accounting and CoA.
Hope this will help you.
Stephen Rodriguez
Yes, it is possible.  Cisco used to have the BBSM and they would use that for portaling.
now, there is no 'integrated' method to do this, I think you would need to look at something like nomadix
http://www.nomadix.com/
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
5 Replies 5
Scott Fella
-Scott
Abhishek Abhishek
Hello Andrea,
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Thanks for all replay.
I have more remote site with local internet access and I need to centralize and share a captive portal/auth service locate in the HQ.
I will evaluate the introdution of vitrual WLC and the AP conversion to flex deploy, in order to add rediretion function.
Thanks again for all your suggestions.
Andrea
Scott Fella
You need to look at really your design and what functionality you want to have. Using a WLC is a good idea in general than autonomous, but you are limited in what you can do with guest and a WebAuth. Like Steve mentioned, Normadix is a thirst part solution for controlling guest access. Panera Bread and other restaurant chains use Normadix for guest access. If you just want a central web portal with no real restrictions, then using a WLC itself is your answer. Typically a good design is to have a WLC5508-12 in the DMZ and you would tunnel traffic from a foreign (internal)WLC to the anchor WLC in the DMZ.
-Scott
