Highlighted
Beginner
Autonomous -> LWAPP Upgrade Tool & Vista
I tried to install the v. 3.4 upgrade tool on Vista Business 64 bit. The installation fails with a pop-up titled "Severe" with error "Error in opening iput file."
The real problem I'm having is that I can't uninstall the failed installation. It shows up in the installed programs list, but upon uninstalling pops up with "Setup Initialization Error" "Setup is unable to find _SETUP.DLL, which is needed to complete the installation. Error 103."
Any advice on how I can excise this thing out of my system?
3 REPLIES 3
Highlighted
Rising star
Re: Autonomous -> LWAPP Upgrade Tool & Vista
try running the uninstall in windows XP compatibility mode.
Highlighted
Beginner
Unfortunately that didn't do the trick. I did look at the uninstall.bat file and tried running the isuninst command manually with the same options and compatibility mode, but it just immediately exists without doing anything.
Highlighted
Rising star
Looks like a manual uninstall and a registry clean for you my friend. Good luck.
Content for Community-Ad
August's Community Spotlight Awards
