Autonoumus AP configuration connection to Cable modem. using AP . AIR CAP3702I-A-K9
Seroj Hacopian
interested in configuration of  AIR CAP3702I-A-K9 autonomous documentations to connect to a cable modem,
I did change the OS from capwap to Autonomous.
5 Replies 5
Below basic configuration will work as long as your modem provides DHCP IP. Modify SSID_Name & Password appropriately
conf t
hostname <AP_HOSTNAME>
dot11 ssid <SSID_NAME>
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii <SSID_PASSWORD>
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid <SSID_NAME>
no shutdown
interface Dot11Radio1
channel width 40-above
ssid <SSID_NAME>
no shutdown
interface BVI1
ip address dhcp
end
write memory
Rasika
*** Pls rate all useful responses ***
Hi Rasika,
not sure why
Ayer(config-ssid)#authentication key-management wpa version 2
Dot11Radio1 Error: Encryption mode cipher is not configured
Ayer(config-ssid)#
following is APs config.
rs#
Ayers#
Ayers#
Ayers#
Ayers#
Ayers#
Ayers#sh run
Building configuration...
Current configuration : 1680 bytes
! Last configuration change at 10:15:17 UTC Mon Mar 1 1993
version 15.3
no service pad
service password-encryption
hostname Ayers
logging rate-limit console 9
enable secret 5 $1$0NaJ$7sEU8WOL286G1B19h57uV.
no aaa new-model
no ip source-route
no ip cef
dot11 syslog
dot11 ssid Cisco
   authentication open
   guest-mode
no ipv6 cef
username Cisco password 7 0802455D0A16
bridge irb
 no ip address
 ssid Cisco
 antenna gain 0
 stbc
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 no ip address
 ssid Cisco
 antenna gain 0
 peakdetect
 dfs band 3 block
 stbc
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 mac-address 88f0.31e6.c824
 ip address dhcp
 ipv6 address dhcp
 ipv6 address autoconfig
 ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
Since radio interface encryption not configured prior to SSID config, this may come.
Try below missing lines again & see if that works
dot11 ssid Cisco
Rasika
I tried to configure DHCP scope for the clients from the GUI who are attempting to connect
and found no parameters for configuration.
wireless clients need ip addresses from AP DHCP server to connect.
does need to be configured from command line?
You can do this via GUI or CLI.
Here is an example config in CLI. You need to configure correct gateway (should be the IP of your DSL modem IP) & proper DNS server info.
ip dhcp excluded-address 192.168.21.1 192.168.21.10
ip dhcp pool VLAN21
network 192.168.21.0 255.255.255.0
default-router 192.168.21.1
dns-server 8.8.8.8
Note that AP cannot do any NAT, so your DSL modem should do this. Ideally you should define DHCP on your DSL modem
Rasika
