Bandwidth control on WLC
jcartes
There is some kind of bandwidth control for ssid guest on the WLC?
satya mothukuri
I think there should a chance of doing this by QoS in WLAN setting.
Satya.M
Amjad Abdullah
you can use QoS roles:
http://tiny.cc/7zx9jw
This will only affect downstream, not upstream traffic.
Amjad
You want to say "Thank you"?
Don't. Just rate the useful answers,
that is more useful than "Thank you".
Rating useful replies is more useful than saying "Thank you"
Leo Laohoo
Depends on what firmware your controller is running.
If you have the new 7.3.X then you now have the options of either configuring bandwidth control on a per-SSID basis or per-user basis.
Wireless Bi-Directional Rate Limiting Deployment Guide
