Resolved! C9120AX-C Not able to join 9800 WLC
C9120AX-C was previously joined to the controller, but for some reason it stopped working. Upon checking it disappeared from the controller. The last join attempt stats below
Hello ,We are having problem with one AP to join the WLC , all others successfully the controlle. the console output is :[*03/19/2024 09:08:50.0003] CAPWAP State: DTLS Setup[*03/19/2024 09:08:50.0035] dtls_process_packet: DTLS Error: 1040[*03/19/2024...
The LED light of 3802 AP is off after registered with 9800 WLC . But the 3802 access point is still working perfectly in providing the wireless connection to the end device . We have factory-reset the AP and issue remain the same after the AP regist...
Hello,What should we do if sometime the web auth for guest WLAN is not showing?
So, this is more a question of what people are using or seeing. We will be replacing all our facilities this year and I plan to go Wi-Fi6E. I have tested having the SSID with mixed, but I have also heard separate doe to if a client shifts frequencies...
I have a single google home that will not stay connected to wireless. This is a network consisting of only two 9115aps and nothing else in the network its having the issue. There is a single google home that disconnects daily and will not reconnect t...
I need some help with configuring an autonomous 1142 ap. I enter the GUI set up two vlans 100 and 200. vlan 100 has corporate wifi and vlan 200 has guest wifi. I signals appear on my phone but when i go to connect to them I don't get an IP address. I...
HI all, we are deploying a wireless eap-tls machine authenticated network. We have a PKI using Windows CA services with one offline root CA and one intermediate issuing CA. For our RADIUS server, I started with a windows NPS server and then changed i...
I have a very simple setup: WLC1 (172.16.0.250) = Primary BACKUP (172.16.0.251) = Backup When the Primary goes offline, my AP moves to the BACKUP wlc as expectedHowever, when the Primary comes back online, the AP remains in the BACKUP and does not "f...
Have an autonomous ap im configuring for use. When i enter the password in ASCII format it tells me I can't use a ? character. Is there any way around this? This is my software version,Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 15.3(3...
greetings,i was wondering what b L a means in an AP Icon of AP map please?a - 802.11ab= 802.11b per what i know but "L", i don't know. best Regards, Masood
Objective is to build a point to point Mesh Bridge with 2 c9124 AP's one running a EWCRunning version 17.13.1Currently I'm configuring a point to point bridge with two c9124 and one is configured as an ewc. the ap mode is only showing as flex and if ...
I have been getting lot of complaints from the C-level about the speed of the wireless network. Tests on the wired network yield 700+ Mbps but the wireless strains to reach 24 Mbps.I do not expect the wireless network to match the wired network in s...
Hi all,I need a little clarification about Cisco wireless tools.Cisco WLC is basically to configure wireless network(ap,ap groups,radius,etc),isn't it?But when I need to monitor APs,clients,RFs,channels,etc...,Cisco WLC is not really "friendly",basic...
Hi,what it is your experience with this antenna in warehouse environment especially for areas between racks? What else did you used it for?How do you choose antenna based on gain for areas between racks? For example, if this area is 60m or longer, wo...
Subject | Author | Posted |
03-15-2024 03:10 AM | ||
03-13-2024 06:06 AM | ||
03-10-2024 03:07 PM | ||
03-06-2024 03:15 PM | ||
02-28-2024 10:04 AM |
User | Count |
22 | |
18 | |
3 | |
2 | |
2 |
