10-14-2019 09:51 AM - edited 07-05-2021 11:08 AM
I am running a Cisco 3702i AP at home with an up to date firmware. It was using PoE into a Ubiquiti switch, but complained it wasn't getting enough power, but connectivity seemed ok, although upstairs it wasn't as powerful. I've added a power injector and it's made no difference. Is there a setting to increase the power?
I have 2 SSID 1 on 2.4Ghz (channel width 20) and the other on 5Ghz (channel width 80).
Also what are the best data rates for each? Or anything else you might recommend?
version 15.3
no service pad
service password-encryption
hostname Cisco-AP1
logging rate-limit console 9
no aaa new-model
no ip source-route
no ip cef
ip domain name home
dot11 pause-time 100
dot11 syslog
dot11 ssid Net-2.4Ghz
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 0148
dot11 ssid Net-5Ghz
authentication open
guest-mode
wpa-psk ascii 7 048
power inline negotiation prestandard source
no ipv6 cef
crypto pki trustpoint TP-self-signed-498917168
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-498917168
revocation-check none
rsakeypair TP-self-signed-498917168
bridge irb
interface Dot11Radio0
no ip address
encryption mode ciphers aes-ccm
ssid Net-2.4Ghz
antenna gain 0
stbc
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio1
no ip address
ssid Net-5Ghz
antenna gain 0
peakdetect
no dfs band block
stbc
channel width 80
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface BVI1
mac-address 80e0.1dbc
ip address 192.168.0.8 255.255.255.0
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip default-gateway 192.168.0.1
ip forward-protocol nd
ip http server
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community 08979890r RO
access-list 111 permit tcp any any neq telnet
bridge 1 route ip
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
login local
transport input all
end
10-14-2019 02:00 PM
10-14-2019 02:20 PM
for the POE draw needs to provide 802.3at POE to the AP otherwise it will turn off radios
The AP 3700 with integrated 802.11ac wave-1 radio is designed to run from Power over Ethernet (PoE) sources, local power, or via mid-span or power injector. If the AP 3700 is powered by PoE and the source is 802.3af (15.4 Watts) the AP will come up and fully function in a 3x3:3 mode, for enhanced performance additional power sources such as 802.3at, enhanced PoE, Cisco PoE Injector-4, or local power may be used. With additional power (greater than 15.4W) supplied, the 3700 will shift into the 4x4:3 mode.
If the customer has lower PoE requirements and still wishes to use the AP 3700 and say the WSSI module, the AP 3700 will still function with the module but in a 2x2:2 mode with the module enabled.
10-14-2019 11:40 PM
10-15-2019 07:29 AM
10-15-2019 08:39 AM
10-15-2019 11:52 PM
