12-04-2018 09:54 PM - edited 07-05-2021 09:32 AM
I am having trouble finding clear information on how to configure two 1572 APs as a wireless bridge.
Currently I have 1 2504 Controller on version 8.0.152.0
I am using a meraki switch to power and connect the APs into the network, in the future it will be a cisco Switch.
I would like to know the exact configuration steps to follow to configure the APs. I have tried multiple things i pieced together from various articles, but they all seem to be outdated. The APs do not seem to be connecting to one another, I checked the radio status and it states down "Dot11Radio0 is reset, line protocol is down"
Additionally, I only have one GHz antenna per AP. Will this be an issue? I was assuming I could just shut down the second antenna.
12-05-2018 07:58 AM
here a document on a workgroup bridge using Cisco WLC
12-05-2018 10:43 AM
I do not seem to be able to do any sort of configuration on the AP side. Is their an example of the WLC side configuration of it?
12-05-2018 10:43 AM
I do not seem to be able to do any sort of confiif changes on the AP side. Is their an example of the WLC side configuration of it?
12-05-2018 09:03 AM
Are you intend to use this as MESH APs ? or use in Autonomous mode like traditional P2P bridge ?
Rasika
12-05-2018 10:45 AM
12-05-2018 10:53 AM
If you do not have autonomous image then you cannot configure it as a traditional bridge (root/non-root bridge). If that was a option you can configure it like below
https://mrncciew.com/2013/11/09/wireless-bridge-with-eap-fast/
With controller based solution, please go through below mesh deployment guide, you may be able to get your requirements fulfil through that solution as well
https://www.cisco.com/c/en/us/td/docs/wireless/technology/mesh/8-5/b_mesh_85.html
Rasika
*** Pls rate all useful responses ***
12-06-2018 02:47 PM
12-07-2018 12:46 AM
It seems it keeps establishing connection. Will it have an issue with connectivity? Does it dissacosiate when it associates with the EAP-FAST? just trying to understand if this is normal.
I keep getting this message:
*Mar 1 04:29:29.439: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP ROOT 502f.a2f0.abc0 [EAP-FAST WPAv2]
*Mar 1 04:29:40.443: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP ROOT 502f.a2f0.abc0 [EAP-FAST WPAv2]
*Mar 1 04:29:51.455: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP ROOT 502f.a2f0.abc0 [EAP-FAST WPAv2]
*Mar 1 04:30:06.407: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP ROOT 502f.a2f0.abc0 [EAP-FAST WPAv2]
*Mar 1 04:30:20.435: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP ROOT 502f.a2f0.abc0 [EAP-FAST WPAv2]
*Mar 1 04:30:30.499: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP ROOT 502f.a2f0.abc0 [EAP-FAST WPAv2]
*Mar 1 04:30:41.519: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP ROOT 502f.a2f0.abc0 [EAP-FAST WPAv2]
*Mar 1 04:30:52.431: %DOT11-4-UPLINK_ESTABLISHED: Interface Dot11Radio1, Associated To AP ROOT 502f.a2f0.abc0 [EAP-FAST WPAv2]
12-07-2018 03:48 AM
12-07-2018 04:03 PM
12-07-2018 07:26 PM - edited 12-07-2018 07:28 PM
What exact model do you have? If you have ‘e’ model, do you have the antennas connected? Also you either need a power injector, ac adapter, 802.3af or hard line power.
12-07-2018 07:51 PM
12-07-2018 08:02 PM
12-09-2018 11:14 PM
