08-22-2019 03:43 AM - edited 07-05-2021 10:53 AM
Good day.
I can’t configure Sonos via WIFI network. Built on CIsco WLC 2504.
Attachment Scheme.
When setting up, you need to press the buttons on Sonos and it starts sending broadcast pacet to the network at the address 255.255.255.255. which the phone connected to the wireless network should see. The controller does not skip broadcast pacet. Enabled in the controller settings
Broadcast forwarding
Enable Global Multicast Mode
May be someone knows how to allow the passage of broadcast pacet through the controller?
Solved! Go to Solution.
08-26-2019 12:35 AM
08-22-2019 06:49 AM
08-22-2019 11:49 PM
Yes. I saw this. I have followed all the recommendations. I can connect to configured SONOS and play music. But I still have problems. I can not perform the initial configuration of SONOS. At the moment of pressing the button, the phone does not see SONOS
08-23-2019 12:09 AM
08-23-2019 12:44 AM
08-23-2019 02:27 AM
08-23-2019 03:46 AM
08-23-2019 06:40 AM
08-23-2019 07:17 AM
08-23-2019 04:13 AM
One more thing, you have Global Broadcast Forwarding enabled? "Controller > General > Broadcast Forwarding > Enabled"
Please note, this can flood your wireless clients and is generally a bad idea.
08-23-2019 06:46 AM
08-24-2019 12:06 PM
08-25-2019 11:32 PM
Controller -> mDNS -> General -> Global snooping checked.
Controller -> General -> Broadcast Forwarding enabled.
Controller -> General -> AP multicast mode set to multicast with the ip 239.255.255.250.
Yes, I made all these settings.
I have attached a screenshot.
Sonos send broadcast packets. Wireless network dont have it broadcast packet.
08-25-2019 11:49 PM
08-25-2019 11:57 PM
