Community Helping Community
366
Beginner
Can a 3802i access point power sufficiently on a normal PoE+ port?
When looking at the 3802i spec sheet it specifically mentions it can utilise and 'needs' UPoE. Can someone please tell me if they can work well enough on just a normal PoE+ port?
The ap itself only seems to draw 30W of power, so was wondering if a PoE+ would suffice.
Thanks.
Everyone's tags (3)
1 ACCEPTED SOLUTION
VIP Advocate
Re: Can a 3802i access point power sufficiently on a normal PoE+ port?
PoE+ will suffice for normal operation. I think this changes if you add a hardware module to it though.
1 REPLY 1
VIP Advocate
Content for Community-Ad
August's Community Spotlight Awards
