Can I connect two CT5760 (Wireless) fow HA just with one stack cable?
Jorge Cantillo
Hi guys,
I have two CT5760 so but just one of them came with a stack cable. Can I do a HA connection with just one STK cable, I friend of mine intentend to do this ask yesteday and he sent me this output:
WLC#show switch stack-ports summary
Sw#/Port#  Port Status  Neighbor  Cable Length   Link OK   Link Active   Sync OK   #Changes to LinkOK  In Loopback
1/1        DOWN         NONE      Unknown        Yes       No            Yes       0                   No
1/2        DOWN         NONE      Unknown        Yes       No            Yes       0                   No
Stephen Rodriguez
you should be able to do it with just one cable, per the 5760 HA guide, two is recommended for a 'full ring':
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/5700/software/release/ios_xe_33/5760_HA_DG_iosXE33.html#pgfId-43194
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Thanks Steve. I will try it today. I've seen both controllers are using Version 03.02.03.SE RELEASE SOFTWARE (fc2) and the Part number is:
NAME: "Switch 1", DESCR: "AIR-CT5760-6"
PID: AIR-CT5760        , VID: V03
Do you know what mean the last 6 of the description?
Thnks
Jorge
according to that document, it is the SKU
Steve
HTH,
Steve
Thanks Steve, I upgraded to IOS XE 03.03.04SE in order to support HA.
