10-01-2014 07:15 AM - edited 07-05-2021 01:38 AM
Hi guys,
I have two CT5760 so but just one of them came with a stack cable. Can I do a HA connection with just one STK cable, I friend of mine intentend to do this ask yesteday and he sent me this output:
WLC#show switch stack-ports summary
Sw#/Port# Port Status Neighbor Cable Length Link OK Link Active Sync OK #Changes to LinkOK In Loopback
1/1 DOWN NONE Unknown Yes No Yes 0 No
1/2 DOWN NONE Unknown Yes No Yes 0 No
Solved! Go to Solution.
10-01-2014 08:12 AM
you should be able to do it with just one cable, per the 5760 HA guide, two is recommended for a 'full ring':
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/5700/software/release/ios_xe_33/5760_HA_DG_iosXE33.html#pgfId-43194
HTH,
Steve
10-01-2014 08:12 AM
HTH,
Steve
10-01-2014 08:55 AM
Thanks Steve. I will try it today. I've seen both controllers are using Version 03.02.03.SE RELEASE SOFTWARE (fc2) and the Part number is:
NAME: "Switch 1", DESCR: "AIR-CT5760-6"
PID: AIR-CT5760 , VID: V03
Do you know what mean the last 6 of the description?
Thnks
Jorge
10-01-2014 09:08 AM
according to that document, it is the SKU
Steve
10-02-2014 07:41 AM
Thanks Steve, I upgraded to IOS XE 03.03.04SE in order to support HA.
