Can't add CISCO MSE 10.2 to CISCO Prime
guzmanmonne
I have installed a CISCO PI 3.0 on our facilities to maintain the configurations of our CISCO devices and to control two wireless controllers.
The discovery process worked correctly and I was able to add both controllers to the CISCO PI.
When I tried to add my CISCO MSE to the PI I hit a wall. I tried to look around for a solution but none work. When I try to add the MSE, I fill the inputs and then an error shows saying:
"No response from Server. It may be unreachable, or server is down or HTTPS connection to server failed."
I can't make anything from this since from the PI I can ping them and the MSE is up and working.
Does anybody knows what the problem is?
There is no integration between PI & CMX 10.x. So you do  not want to do this.
Only thing you want to do is give PI credential when setting up CMX while synchronize maps & controller information onto CMX.
Rasika
*** Pls rate all useful responses ***
6 Replies 6
Rasika
Ok, great!
I didn't knew that.
Thank you.
any suggestions on doing this procedure?
Please open a new thread with more details about your used products and what you try to achieve.
Sir I have also recieved same error. Could you please explain the resolution in more details.
Thank you
Jun Zhou
Now you can do it with PI3.2 abover and CMX10.3 abover.
