01-15-2015 05:33 AM - edited 07-05-2021 02:16 AM
Is it possible to create EoIP tunnels to two different Anchor Controllers on two different DMZs from a single WLC. So we can tunnel the traffics of two SSIDs to different DMZ environments.
Anchor Controllers can create 71 connections to Foreign Controllers, but can Foreign Controllers create EoIP tunnels to more than 1 Anchors.
Sinan
Solved! Go to Solution.
01-15-2015 05:54 AM
Yes you can do that. Just keep the number of EoIP tunnels down to below the max.
-Scott
01-15-2015 05:54 AM
-Scott
01-15-2015 05:56 AM
Just to note, an anchor WLC can be a WLC in the DMZ or even another foreign WLC which you want to anchor an SSID to. You only limited in very large environments when you might hit that max limit.
-Scott
01-15-2015 06:41 AM
Thanks for the information.
