Highlighted
Beginner
Can WLC create EoIP tunnels to more than one Anchor Controllers
Is it possible to create EoIP tunnels to two different Anchor Controllers on two different DMZs from a single WLC. So we can tunnel the traffics of two SSIDs to different DMZ environments.
Anchor Controllers can create 71 connections to Foreign Controllers, but can Foreign Controllers create EoIP tunnels to more than 1 Anchors.
Sinan
1 ACCEPTED SOLUTION
Highlighted
Hall of Fame Master
Yes you can do that. Just keep the number of EoIP tunnels down to below the max.
-Scott
-Scott
3 REPLIES 3
Highlighted
Hall of Fame Master
-Scott
-Scott
Highlighted
Just to note, an anchor WLC can be a WLC in the DMZ or even another foreign WLC which you want to anchor an SSID to.  You only limited in very large environments when you might hit that max limit.
-Scott
-Scott
Highlighted
Thanks for the information.
Content for Community-Ad
