06-22-2007 03:34 AM - edited 07-03-2021 02:14 PM
Hi all,
I made a lot of tests during some days with a wlc4402 and everything was ok.
One day when I tried to reset the system I had a lot of errors (see attach) and could not go on. After changing the image the following output appeared: "RAM Disk Image Integrity Check Failed (Bad Magic Number) Hanging". Now I have no response from the controller.
Somebody already had this kind of problem?
06-28-2007 02:16 PM
Try upgrading the controller to 4.0.1.155 or or 3.2.x.x.
12-16-2007 12:36 PM
I want to the result,because I met the same question,can not connect to the console after the failed of upgrade the image.
and I have to said,when the console said no ennough flash room. I reformat the flash (press ESC)
so ,pls help me!!!!!!!!!!!!
thank you.
12-16-2007 12:37 PM
thank you.
05-07-2012 12:34 AM
What is the solution to this problem? I have the same problem. was it a H/W failure?
