Showing results forĀ
Search instead forĀ
Did you mean:Ā
Capwap - Vlans allowed on Capwap tunnels
michalis1234
Dear All,
I have a 3850 switch that is acting as a Mobility controller. I would like to limit the allowed Vlans that are propagated to the APs.
I am attaching  the "sh int trunk" from the cisco switch. Vlan 100 is the AP Management Vlan, 200 - 220 are the client Vlans for my users.
I am concerned about the security of my installation for example I have 3 Vlans (10, 20, 50) that I would like to be completely isolated from the
wireless lans - Vlans. How can I stop these 3 Vlans from propagating to the APs ?
Thank you in advance.
Ok, I got it.
I do not think there is a way to control this. These tunnels are automatically establish and no way to control via config (as far as I know)
Rasika
7 Replies 7
You have to configure all your AP connected switchport as Access Port & not trunk ports.
Rasika
*** Pls rate all useful responses ***
I have attached the configuration of the ports that are connected to my APs.
All of them are access ports on the AP Management vlan 100.
Isn't it very weird ?
Port        Vlans allowed and active in management domain
Ca0         1,10,20,50,100,200,210,220,300
Ca1         1,10,20,50,100,200,210,220,300
Ca2         1,10,20,50,100,200,210,220,300
Ca3         1,10,20,50,100,200,210,220,300
Ca4         1,10,20,50,100,200,210,220,300
Above are tunnel established (automatically) between your MA/MC switches (I believe you may have 5 switches). These are not indicating all those vlans are trunk to APs.
If you get "show interface capwap <interface_number>" you will see between what end point each tunnel interface map to.
Rasika
Hi Rasika,
No I have only one 3850 switch that acts as MC.
The sh int capwap command show that the tunnels are established between the svi (Management vlan: 192.168.100.1) of the 3850 and the APs.
regards,
Ok, I got it.
Rasika
Ok thanks, but what about security ?
If i would like to setup a dmz vlan on the same switch in order to isolate 2 servers from the wireless networks. I cannot using that single 3850 switch?
In this situation i have to use a second switch?
Thanks for your prompt replies!!!
mohanak
If you are using AP in local mode then use AP port as access and put in native/management port.
