Hello
I have all ready configured a WLC 5508, I have a SSID in flex connect mode.
The APs that I have in the remote Office are in flex connect mode also I configured the extenal web authentication ACL and in the policies i configured the Flex connect ACL to redirect the guest devices to the ISE login page.
I have the same ACL and Flex connect ACL name and configuration.
The devices that connect to the guest SSID on the central office have network access the sponsor work well, the client can open the web browser and the WLC and ISE send the web portal login page the users can write the user and password and the ISE and WLC give the access to internet but when the clients try to connect in remote office the login page works but when the client is alredy authenticate and has the network access, the user open a new web pache or browser and the login page apear and if the client write the credentials the device has not access. is like a loop with the login page.
If i disable the flex connect on the SSID the spponsor works well
the version of the WLC is the 8.2.100.0, before the WLC has the 8.0.x
AP 3702, before install this AP was a 1242 and with this model of AP the sponsor central web auth works well on the remote office
ISE version is the 1.3
someone can tell me how I fix the ACL on the flex connect APs, Why the 1242 APs can work ok thin the flec connec ACL an central web policies?
