Community Helping Community
417
Highlighted
Beginner
Central WebAuth WLC with local switching
Hi Guys,
I am trying to configure a guest WLAN using central WebAuth via Controller SplashPage and after succesfull Authentication local switching in the remote sites Guest WLAN/VLAN.
- Using Flexconnect I connected the remote AP to the WLC and set its mode to Flexconnect.
- SSID is configured with L3 Security Web Policy Authentication.
- FlexConnect Tab on AP Settings is set to VLAN Support with native VLAN (103 management VLAN) and the mapping then set to the remote sites guest VLAN (104).
- at the remote site the client can reach a dhcp server in VLAN 104.
Now if I connect a client to the remote guest WLAN it does not get an IP. Do I need to set something else in the settings?
Is this scenario possible to configure and supported?
Thanks in advance!
3 REPLIES 3
Hall of Fame Master
Re: Central WebAuth WLC with local switching
Did you create a trunk port from the AP to the switch and verify the vlan the guest are suppose to be on  is forwarding?  Is that vlan 104?
-Scott
Beginner
Yes AP is connected to a trunk Port with the remote guest VLAN (104) and the native/management VLAN.
To isolate create open-ssid and check.
Content for Community-Ad
August's Community Spotlight Awards
