01-18-2018 05:21 AM - edited 07-05-2021 08:07 AM
Hi Guys,
I am trying to configure a guest WLAN using central WebAuth via Controller SplashPage and after succesfull Authentication local switching in the remote sites Guest WLAN/VLAN.
- Using Flexconnect I connected the remote AP to the WLC and set its mode to Flexconnect.
- SSID is configured with L3 Security Web Policy Authentication.
- FlexConnect Tab on AP Settings is set to VLAN Support with native VLAN (103 management VLAN) and the mapping then set to the remote sites guest VLAN (104).
- at the remote site the client can reach a dhcp server in VLAN 104.
Now if I connect a client to the remote guest WLAN it does not get an IP. Do I need to set something else in the settings?
Is this scenario possible to configure and supported?
Thanks in advance!
01-18-2018 12:19 PM - edited 01-18-2018 12:20 PM
Did you create a trunk port from the AP to the switch and verify the vlan the guest are suppose to be on is forwarding? Is that vlan 104?
01-18-2018 11:27 PM
Yes AP is connected to a trunk Port with the remote guest VLAN (104) and the native/management VLAN.
01-20-2018 08:40 PM
