313
Highlighted
Beginner
Certifications for IW3700 Series for outdoor use?
Dear all,
Just having a look at IW3700 series datasheet and the possibility for outdoor use.
Is someone here who can give me a hint regarding the note there:
"Sections of the following standards are referenced for Cisco IW3700 Series Access Points certifications:"
Are the standards below (e.g. IEC 60068-2-6 (Vibration)) affected from that statement or are there just no "Industrial Compliance Standards" available?
I am referring to the Technical Data here:
https://www.cisco.com/c/en/us/products/collateral/wireless/industrial-wireless-3700-series/datasheet-c78-734968.html
Thanks and best regards!
Everyone's tags (2)
1 REPLY 1
Participant
Re: Certifications for IW3700 Series for outdoor use?
I don't understand the question.
They are IP67 rated so yes, can be used outdoors.
Further regulatory info here;
https://www.cisco.com/c/dam/en/us/td/docs/wireless/outdoor_industrial/iw3702/regulatory/RCSI-0161-book.pdf
If this doesn't answer the question, can you re-phrase it please?
Content for Community-Ad
August's Community Spotlight Awards
